Bought this off ebay, it's got stored ecgs on it and under "ID" it says "select study". I just want to wipe it back to original and remove these ECGs. Any ideas?
Hey Bro,
First, tell me what model of MORTARA ECG are you referring to. I work with different models of MORTARA ECG for some times. Maybe I can help you.
Hey Bro,
ELI 350
Your post is correct and informative.
Hello Andy, I have a Mortara Eli 10 and trying to reset back to factory. Any ideas?
SOURCE: NEED PARTS MANUAL OF GE MARQUETTE MODEL MAC 5000 RESTING ECG
I have manuals and all kinds of stuff for tech support. Let me know how I can help if you are still in need of help. [email protected] 800 989 4909. Jeff Watson
SOURCE: Schiller AT-1 ecg not printing.
Turn on machine, wait a few seconds then press ALT-0-1-1
You will get a print out showing all the settings
SOURCE: the schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
SOURCE: I wish to down load Operations and Service Manual
I have it, let me know if you still need it. [email protected]. www.overstockme.com. Jeff Watson
SOURCE: loading paper into the MAC 1200 ecg machine
1. Switch on the recorder
2. Pull up the handle of the paper door and fold it out
3. Remove the cardboard from the top of the new pad and place the pad, including the cardboard backing at the bottom and with the arrow pointing towards the unit, into the paper compartment
4. Pull the top sheet out of the compartment and guide it around the guide roller
5. Holding the leading edge of the paper in place between the two markers on the recorder, close the paper door. Ensure that it locks into place on both sides.
- When inserting an already started Z-fold pad, the grid side must face up and the first fold must point the compartment.
(You can find more information at MAC 1200 Operator's Manual, there page 59.)
