SOURCE: hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
SOURCE: low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1. Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
SOURCE: Just purchased M1522nf laser jet printer. LCD
If you get suppy memory error than replace the Toner cartridge.
On toner cartridge there is a copper connecting chip, that particular chip communicates with the printer.
However the chip on ptinter (EPM) which communicate with cartridge chip if that is faulty than you need to get printer repaired.
However first replace the cartridge.
Chip on cartridge may be faulty.
SOURCE: memory full hp 3055 laser jet
This is about send fax resolution problem, refer with this article:
http://www.topresource.net/info/103/hp_laserjet_3055_low_memory_problem_while_send_fax.html
