I bought new caps for my tv and when I put one on it would get hot and blow, am I putting it on right?
You might be connecting the capacitors wrongly, i.e., positive terminal on negative and negative terminal on positive. Other chance is that the replacement capacitor may not have same voltage/wattage rating as the original. Another chance is that the portion you are replacing the capacitors might be having excess voltage coming in, due to failure of some regulation.
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
CAR OVERHEATING
There
are many possibilities for car overheating.
Faulty
thermostat clogged radiator/plugged radiator, radiator hose worn out. Coolant
running low. Low coolant pressure. Faulty temperate sensor.
I
suggest you to go through the troubleshooting details mentioned in the link
below:-----
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
These will help.
Thanks.
