Motorola Mobility H700 Wireless Headset Logo
Posted on May 03, 2017
Bluetooth ok where is the passcode set up? it never asked me for a passcode when I first set it up. I just said look for devices and it found it and picked it up, and worked until yesterday morning. I keep it charged all the time, every night when I get home I put it on charge. Am I charging it too much? It beeps when i push the button on the earpiece, it just wont pick up when I get a call, only on my handset. My phone has the little blue thing in the screen and it flashes blue on the back and on my earpiece when I connect it. bloop38
5 Related Answers
Anonymous
  • Posted on Apr 20, 2007
SOURCE: Phone wont detect bluetooth H700
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
A
Anonymous
  • Posted on Jun 03, 2008
SOURCE: calls not coming through
Add me to the list! My headset just started doing the same thing and I can't figure out what to do!
Anonymous
  • 405 Answers
  • Posted on Jul 02, 2008
SOURCE: resetting passcode for Motorola H350 bluetooth earpiece?
Good Day,
The passcode by default is "0000", there is no way to reset it or change it.
Hope this helps
Anonymous
  • 14 Answers
  • Posted on Jan 10, 2009
SOURCE: bluetooth not working
Make sure you have connected the bluetooth correctly, if you have and it still doesent work, your phones bluetooth capabilitys my be Gliching or broken. Also make sure you turn the volume All the way up.
Schmead10
Joe Negus
  • 652 Answers
  • Posted on Aug 07, 2009
SOURCE: motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
2answers
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 • Cell Phones
3answers
What is the passcode of the bluetooth?connecting to a computer
The passcode for connectivity will probably be listed on your computer once it finds and attempts to pair with your phone. Generally when connecting a Bluetooth device, a passcode will be displayed on the host computer in order to ensure that only authorized devices are being connected.
Here is a guide I found for setting up Bluetooth on this device:
http://www.knowyourmobile.com/sonyericssonk800iuserguides/255/setting_up_bluetooth_on_the_sony_ericsson_k800i.html
2answers
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 • Cell Phones
1helpful
2answers
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
3helpful
1helpful
Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
7helpful
Cant pair my wep 500 with my phone
passcode = 0000 (4 zeros) USER GUIDE
The first time you turn on the headset it will enter "Pairing" mode. In this mode you can connect your headset with your phone or other Bluetooth enabled device. If you have already connected one device to the headset, you can enter Pairing mode by holding the multi-function button turns solid blue.
Once in pairing mode, set your phone or other Bluetooth enabled device to search for the headset. While each device is different, the setting is often found in a "Settings" or "Bluetooth" menu and the "Search" or "Discover" Bluetooth devices option. On the list of discovered devices, choose "Samsung WEP500" and select "Yes" or "Ok" to connect to the device. When asked for the passkey, enter 0000.
I switched from Sprint to At&T, and the bluetooth worked for my Sprint phone, I'm currently installing it into my AT&T phone and it has found the device. On the side of the bluetooth itself the...
M540
To pair your phone with another Bluetooth device:
1. Select (home) and press (Menu/OK) > Tools > Bluetooth >
Add a New....
2. Select a device category and press (Menu/OK). (Your
phone will display a list of discovered in-range
Bluetooth devices.)
 Select from: Headset/Car Kits, All, Phone, PC, or
Printer.
3. Select a device and press (Menu/OK). Select Info (right
softkey) to obtain more information about the
device prior to pairing.
4. Enter the passkey and press (Menu/OK).
5. Enter a unique Device Name and press Done (left
softkey).
Please rate this answer
2helpful
Agreed bluetooth passcode required to pair phone and hands free k
1. Make sure that the mobile phone is switched on and the battery is
charged.
2. Switch on the Advanced Car Kit. For further information, see
“Switching the Advanced Car Kit on/off,” p 20.
3. Open the Bluetooth menu in the mobile phone and activate the
Bluetooth function.
4. Make the required settings on the mobile phone to activate a search
for Bluetooth devices within range. For further information on the
settings required on your mobile phone, see the relevant user guide.
5. Select Advanced Car Kit from the list of Bluetooth devices found.
6. When prompted, key in the Bluetooth passcode 0000.
24helpful
5answers
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
