I just replaced the bulb in my piece of S%^& panasonic PT-50LC13 televison 2 months ago for the 3rd time in 3 years. Today the TV stays on for apx 1 min then turns off. The red led indictator blinks continuosly. What should I do? I just replaced the bulb in my piece of S%^& panasonic PT-50LC13 televison 2 months ago for the 3rd time in 3 years. Today the TV stays on for apx 1 min then turns off. The red led indictator blinks continuosly. What should I do?
the power turns off, then the red blinks 5 times and the orange 2 after. what do i need to replace and how much? the power turns off, then the red blinks 5 times and the orange 2 after. what do i need to replace and how much?
You can't post conmments that contain an email address.
they do this capacitors on board go bad you will need to open i tand check. the ones that go bad are swollen and round on top they should be flat with a x on top.If you dont know what i'm talking about then you will have to take it in to get fixed
Check the power light for blink code--usually if this model shuts down the power light will blink in a sequence--3 blinks a pause and 3 blinks is short protection--usually means a convergence circuit problem.
Let me know what you find--I am here to help.
if this helped you rate this solution as I do this here for free.
It is very common for the high voltage tranformer or flyback to wear out and not provide adequate power to the tv. You can test them with an ohmmeter to see how much powrer is being sent to the main circuit board. You can get parts at tigerdirect.com
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Panasonic Power Light Blinks Orange twice.The lamp was changed out two months ago and lamp hours reset at that time. Please help!
