Hi on trying to upgrade my tomtom300 from basic sd card downloaded upgraded system to a 512sd card but when replacing card unit shows card rejected with red cross ,any helpers please
There is a good chance the programs etc did not copy to the card. If you have a card reader, check to see if there are programs on the card. Make sure you do not have the sd card write protected, open the small hole on the side of the card, copy the programs again to the card.
If you're refering to upgrading your Navigation software, QuickGPSfix data and/or your current (out-dated) map, you can do it by connecting to the TomTom website (www.TomTom.com) using the TomTom HOME or MyDrive Connect software, depending on the model/version of your GPS device.
If you're refering to upgrading your GPS hardware/equipment, to have more capability/features, the device is not hardware upgradable, except for adding/using an SD card with a higher storage/memory capacity (to store more info/maps, etc.) ... provided you have a GPS device with an SD card slot.
You'll want to consider buying a newer model with more capabilities / features than what you have now.
Does you Motorola Motonav TN30 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN30 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN30:
Start by downloading the Motorola Motonav system software from Motorola from here.
Extract the files onto an SD memory card.
Make sure your Motorola Motonav is fully charged.
Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
Insert the SD memory card
Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
The full upgrade process can take up to 15 minutes.
When the software upgrade is complete, your Motorola Motonav will
automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
Does you Motorola Motonav TN20 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN20 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN20:
You may have not written the entire program to the SD card. If you saved the program prior to the upgrade, start tomtom home program and reinstall the program. then upgrade again. The tomtom home program is not as user friendly as you would hope. Also turn the unit off, take out the card and then reinsert and turn the unit on again.
