Question about Quinny Buzz 3 Stroller
Can I fit other makes of solid tyres to my quinny buzz don't like the inflatable ones
2 Suggested Answers
6ya staff
SOURCE:
Marie Lowe
  • 223 Answers
SOURCE: Need a replacement rear tyre for Quinny Buzz
Hi you can get them on ebay
Posted on Aug 07, 2010
What should the tyre presure be on my quinny buzz
Hi
The rear tyres should be inflated to a maximum pressure of 26psi (1.8 bar)
Jun 25, 2012 | Quinny Buzz Three Wheel Stroller
Hi, the tyres on my quinny buzz seem to be flat (I can press them right down with my finger) but the inner tubes are fully inflated and do not have a puncture, is this normal?
Both Bugaboo and Quinny recommended tyre inflation pressure as 15 psi / 1 bar. I find this way to soft and run my tires at 30 psi / 2 bar with no problems and far easier pushing.
Feb 08, 2011 | Quinny Buzz Three Wheel Stroller
I have the quinny buzz and have a problem with one of the rear wheels. It appears to have 5 holes in it (around the inner part that attaches to the plastic centre part, they are very small holes and I had...
hi this is a very easy fix have you searched the web for quinny buzz inner tubes? ebat has loads if you are in the uk
or it is a 12 inch bent valve inner tube my advice is when you have repaired these put in tyre slime
this will help any future punctures by repairing them immediatley and you wont even know
very good stuff had it in mine and never had to pump them up good for any inflatable tyres with an
inner tube
Nov 16, 2010 | Quinny Buzz Three Wheel Stroller
Do you get off road wheels for the quinny buzz 3?
You can buy an all terrain air inflated wheel unit, very similar to the rear wheels for the front of the Buzz 3 direct from Dorel, go to http://www.dorel.co.uk/contact-us/ or Tel: 01842 763281., they are always super helpful and very nice. Or you can buy them from this retailer (which I found to be a good deal cheaper) http://babyequipmentcomplete.com/main_site/main/index.php?pge=check or on ebay which are definitely more expensive for new wheels, but perhaps not for used ones. The all terrain tyres are meant to be much better over rougher terrain (as the names suggests) because they are air inflated and make for a much better ride for your little one, however I am just about to buy one myself so I'm not sure how true that is just yet. Remember, as with the rear wheels, that you may have to deal with punctures when using these too! Hope this helps.
Feb 28, 2010 | Quinny Buzz Three Wheel Stroller
Is it possible to convert the Buzz 3 front wheel to an inflatable tyre? If it is I'd like to do it - it will overcome the problems of pushing on rough terrain!
Quinny do an All-Terrain front wheel that replaces the front wheels on a Buzz 3. It's basically two new front wheels that are slightly bigger and pnuematic. Worked a treat on a recent holiday to Brixham where we took our Buzz onto the un-surfaced coast path. We got ours from www.babycare.nl a dutch site that sells Quinny Spares it costs Eur62.50.
Jan 16, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
No quinny spare parts retailer in the Uk !!!!
Please have a look at these links:
Rear tyre
Rear tube
International shipping available.
These are actually original spares, directly from Quinny, but as the text states, the sizes used on the Quinny Buzz are quite common.
With kind regards,
Babycare.nl
Erwin de Raad
Jun 11, 2009 | Quinny Buzz Jogger
Buzz rear wheels wont inflate anymore
I just ordered new tyres and inner tubes from my local pram shop. 8.50 for tyres each and 5.50 for inner tubes. Pram centre in Glasgow. Also ordered a new front wheel for 29.
Mar 11, 2009 | Quinny Buzz Three Wheel Stroller
Quinny Buzz 3 Stroller Logo
192 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
