The model is: HP PL506oN
SOURCE: hp 42 plasma tv cptoh 0602 I get sound but no picture
I had the same problem today, Hp wanted $629+tax to fix. With a little mechanical ablity anyone can fix this.
1. remove back covers
2. left-hand side is the video board
3. two white fuses
4. replace
this fixed mine and they only cost $1.50 each
SOURCE: my hp 4260 plasma tv when blank but still have sounds
contact us to be part of a group that is taking action because HP sold this TV with KNOWN problems. Consumers need protection! [email protected]
SOURCE: Magnavox 42" tv has no picture, but still has sound
Hi there! Sounds like the Y-Sustain and/or Z-Sustain boards. This should be written on the boards. Check the fuses on these boards and if found to be blown try replacing with the same rating fuse and see what happens. If not successful then the boards will have to be replaced. You may have to also replace the control board if these come in a kit and not loose. Also check the voltages to these boards. The Power Supply also have a role to play in all this. Please beware of High Current!!! Best Wishes and Good Luck, JUS004
