Watches Logo
A
Anonymous Posted on Jul 18, 2012
Manual for Fossil watch BQ9385/10 ATM
We need an owners manual for Fossill watch 10 ATM BQ9385 so we can have instructions on operations and changing settings, etc.
Joseph Dawe
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 19, 2018
Joseph Dawe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
617
Points
I also have a fossil bq9385 what battery is in it
5 Related Answers
Anonymous
  • Posted on Feb 21, 2009
SOURCE: Instruction Manual for Fossil Watch
-> Go to fossil.com
-> Customer Care
-> Product Info / Watch Instructions
-> Do a mouseover on the various headlines to see the design of your watch.
-> Download desired PDF file
Problem solved. Thank you!
Anonymous
  • Posted on Apr 04, 2009
SOURCE: Set time on Fossil DQ1138 Watch
Press and hold the SET button (it will read CHIME with a flashing on or off). Then push the MODE button - the top will be flashing 12-HR or 24-HR. Push the ST/SP button to toggle between the 12-HR to 24-HR reading. Push the MODE button to get to the hour/minute/second/year/mo-day/month/day value you want to change. Push the ST/SP button to increase the value, the RESET button to reduce the value.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jul 15, 2009
SOURCE: Need to remove links in metal watch band Fossil 10
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 15, 2010
SOURCE: I GOT A FOSSIL WATCH PART#FS4487 WITHOUT AN OWNERS
Click on my profile (escapement), then click on Tips and tricks. There you will find link to Fossil watch manuals. Rate me, plz.
Anonymous
  • 714 Answers
  • Posted on Feb 24, 2010
SOURCE: on time atomic watch wrong time zone
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
6helpful
2answers
How do I set my Fossil watch? It has three dials on the face (looks like one for day of week, one for day of month (goes to 31) and one for seconds). Has only one pin on right side. Says !)ATM on face....
Fossil do not have a list of instructions under model numbers but issue a list of generic instructions which you have to wade through to find the one that suits your watch.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and put your cursor over each of the ones listed in the Multifunction section until you reach the one that looks nearest yours and download the file.
5helpful
2answers
I need an instruction manual for a fossil fs2919 watch to set the dials
Follow this link and download manual for your watch:
http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10
Looking for Fossil Twist ME1020 owner's manual
As a last resort you could contact Fossil and ask them to send you one!
1helpful
I cant find a battery for my Fossill Abacus Wristnet AU 4005
Hai,
It has a Powerful rechargeable Li-ion battery so there is no need to purchase extra battery kits!
Came with no instructions
Just did some checking for the manual. You can try emailing Fossil directly at the following email address:
email: [email protected]
Apr 24, 2009 • Watches
Help! I need instruction manual for Fossil watch
If you go to www.fossil.com you can find the manuals for most of their watches.
Fossill Man's wrist watch FS4252
go to fossil.com and click on custumer support that is where all the manuals are hope this helps
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
