I need help wiring the interlock switch. the colour wires are blue, white and black... the pins are numbered 3, 4 and 5
Blue at top (5)
White in middle (4)
Black at bottom (3)
I found this pic on Google images. Hope this helps. I was having the same problem as the whole door lock and the wiring connectors were all melted because of a short. Samsung washer door interlock mechanism and wiring connections.
I am sorry buy Fixya has no wiring diagrams.
SOURCE: 1992 Isuzu Rodeo Radio Wiring Diagram needed.
http://www.the12volt.com/installbay/vehicles.asp try this site out and see if it will help you.
SOURCE: kia optima 2004 transmission selector wiring colour diagram
Try this website www.kiatechinfo.com
This will be far more usefull than me just handing you the diagram
SOURCE: needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
SOURCE: 1979 Toyota Hilux alternator wiring
always, counterclockwise starting with blue, then yellow, then red
SOURCE: I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
hoping it"s help to solve your problem,ty
