Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Dec 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Cabrio Washer Error message code F1
Our washer gets an "F1" error message when it's got 17 minutes remaining in the complete cycle. any ideas?
Cliff
Thankfully I found this site and it helped me understand the F1 problem. I have an extended warranty that should cover the repair but I wanted to weigh in as just another consumer with the problem.
  • azmijebali Dec 14, 2008
    I am getting an f1 problem after starting the washer
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Dec 14, 2008
Anonymous
Expert
Level 2:
Answers
85
Questions
0
Helped
30639
Points
187
F1 code means the main control needs to be replaced. pretty common repair
2answers
I have a Whirlpool Cabario. I keep getting an error code of F1. I hit cancel and then start several times and it resets itself and continues. The same thing happens when it is about to start the rinse...
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
5helpful
2answers
Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
1helpful
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
2answers
WRONG POWDER'S, TO MANY POWDERS IN PUMP PUT ONE TEASPOON OF OIL IN WHERE THE POWDERS SHOULD GO AND RUN CYCLE AND THAT WILL DESROY THEY SUDS AND ONLY USE HIGH EFF DETRG. FROM NOW ON, IF THAT DONT FIX PROBL YOU HAVE SOMETHING STUCK IN YOUR PUMP, YOU WILL HAVE TO HAVE TECH TO TAKE YOUR FRONT OFF MACHINE AND GO INTO PUMP WHICH IS EASY AND REMOVE ITEM, PROBL SOCK, OR UNDYS. I HAD THIS PROBL WITH MINE.
according to the service manual for the cabrio f-1 means main motor control failure the brain so to speak has a glitch it is intermitten but will eventually fail.
4helpful
3answers
The following list of codes indicates a possible electronics communication problem with the washer:
Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Pause/Cancel twice.
PLACEHOLDER FOR ART
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Please do not forget to rate and comment about your experience with fixya today.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
