Question about Sharp UX B700 Plain Paper Inkjet Fax
Cant get the date and month. and to put my fax number in i need help the machine work, i just brought new ink. i dont have the book.
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 29 Answers
SOURCE: How do I enter phone numbers into the address book for faxes
select (custom settings) then (address control)
then (diret address) its easy from this point
Posted on Mar 10, 2009
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
Apr 12, 2011 | HEWLETT-PACKARD HP 2140 Fax
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Fax keeps saying out of ink
You can also put the machine in serves mode by unplugging the power from the machine, press both the the copy/help and the stop buttons at the same time, hold them and plug back the power until you see TF662B service mode.This also works well with refill cartridges. YJ
Feb 05, 2009 | Sharp UX-B750 Inkjet Fax
FAXING SAYS CANT SCAN TROUBLESHOOT ROUTING , DONT HAVE A BOOK
usually something on scan glass..ord lamp is bad..try coping blank paper..if line shows up...check glass clean and try again..
Dec 26, 2008 | Brother DCP 7010 Multifunction Laser...
Brought new ink , but still saids it low
reprogram the machine/printer then reinstall the driver and then try again. if still not work replace the ink cartridge be sure you cant touch the sensitive part of it.
Jun 11, 2008 | HP 1040 Plain Paper Inkjet Fax
Move to a different phoneline
You need to change the phone number in the settings menu to reflect the new location. Erase the old, enter the new. Dont forget the area code, if different.
Jun 10, 2008 | Muratec F320 Plain Paper LED Fax
New ink roll in Philips fax Magic 2
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OK
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
TO PUT IN INK AND USE FAX
The ink snaps pretty hard into this unit. Make sure take the little clear tape off of the bottom of your ink cartridge. Open the fax machine, if there is already an ink cartridge there, you have to pop it out. Pull it from the top colored part of the cartridge. Take your new cartridge with the side with the number on it facing you, and just push it in. It's easy, it just might seem like it's not going in right because it is kind of hard, you have to push it a bit to get it to snap in.
Sep 05, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Sharp UX B700 Plain Paper Inkjet Fax Logo
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
