Question about Fisher and Paykel GWL11 Top Load Washer
Frigidaire Model GW608F top loader won't fill it trickles in some water and then stops
    Master:
  • Fisher and P... Master
  • 745 Answers
Replace the cold water solenoid
Posted on Apr 21, 2018
6ya staff
SOURCE:
luisa_sgro
  • 713 Answers
SOURCE: Fills with water and then stops and beeps and
Hi just read your posting.The 2 lights that are flashing means your machine has not detected any water level difference.1st turn off both hot and cold taps and 1st remove the cold inlet hose from the machine end,Put the end of the hose into a bucket and turn the tap on.You should get a good flow of water.If you do not get a good flow of water then remove the tap end of the hose and see if you are getting water out of the tap.Check the inlet filters on both ends of the hose to see if they are blocked.If they are blocked clean them with a brush.Check also the water valve end where the hose connected to the machine to see if this filter is blocked. Once you have water coming out of the hose and all the filters are clean refit the hose and repeat to the hot hose.Now select a cycle and push start.If the water flow is good then the machine will work properly.If you still get slow water even when you have good pressure coming out of the hoses then your water valves are faulty.Please reply on how you got on and for further advice.looking forward to your reply.
Posted on Sep 22, 2010
paulus649
  • 72 Answers
SOURCE: My 7-8 year old top load FP washer is slow to fill
check the water filters by the tap and the machine connection
Posted on Sep 25, 2010
charmae_magh
  • 9 Answers
SOURCE: Fisher&Paykel model GW711 top loader
why life so unfair ?
Posted on Jan 27, 2011
richroth
Richard Roth
  • 9472 Answers
SOURCE: the cold water only trickles
You will need to replace the "cold water valve" with this part.
Posted on Jan 30, 2011
kieren lowe
  • 330 Answers
SOURCE: My top loader washing machine
The inlet valve has failed & needs to be replaced unless you don't use hot water then you could just swap the hoses over.
Posted on Feb 18, 2011
We have a Frigidaire top load washer model FFTW1001PW and wash light blinks and it starts but stops right away. We have checked lock and hoses and fuses and screens and it still isn't working. Any ideas?
This sounds like a similar fault I repaired on a Fisher Paykell top loader smart drive. It would fill up, start it's wash cycle (you'd hear the engine turn back and forth ) and a second later stop. It turned out that a position sensor on the motor had failed due to a small water leak. I'm unable to find the motor for your model of Frigidaire to see if there is a similar sensor or pick up module though.
Sep 07, 2018 | Frigidaire Washing Machines
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool lsb6000pq2 washing machine won't fill with water
Humming could be a blockage on the fill solonoid valve remove water fill hose and clean the filter at the valve it pulls out or use an old toothbrush
Jun 26, 2012 | Washing Machines
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Open Questions:
See all Fisher and Paykel GWL11 Top Load Washer Questions
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
