SOURCE: Horizontal line, audio ok
It sounds like you have lost the vertical sweep circuits, it can be the Vertical out put IC is bad, Vertical yoke winding is bad, caps is bad. You will have to open it up, but you must be real careful since the picture tube can hold high voltage (24~30,000 Volts) for a long time after the monitor is unplugged, you will need to discharge the picture tube first before working on it. You may want to leave this to the pro.
http://s807.photobucket.com/home/budm/allalbums
SOURCE: LG Flatron 795FT Plus - horizontal lines on screen
YOU NEED TO CHECK TO SEE IF THE CAPASITORS ON THE POWER SUPPLY AND MAKE SURE THERE NNOT BULGED OUT OF LEAKING IF THEY ARE THE NEED TO BE REPLACED
YOU SHOULD BE ABLE TO FIND EVERYTHING YOU NEED AT RADIO SHACK FOR LESS THEN 20 BUCKS
