My Samsung Digimax A502 Battery Cabinet got broken. I mean the lock. I adjusting it with some plastic sheet. Where can i change the New cabinet cover.......
SOURCE: Samsung digimax 360 lens/lcd problem
see this post....
samsung camera problems
turns out there is a problem with a chip in the camera that breaks.
it costs about $200US to fix
dozens of other models and customers have the same problem.
SOURCE: Samsung Digimax S700 is frozen with lens open
the beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
SOURCE: owners manual
http://www.retrevo.com/samples/Samsung-Digital-Camera-manuals.html get manual here
SOURCE: My Samsung Digimax 420 keeps saying low battery!
Check that you are using the correct type of batteries and that they are rechageable as i found i had a similer problem when using just normal non recargeable
