When I turn on the ps it give me the following message The file system on the system storage is corrupted and will be restored. I press ok them it start restoring but when it finish it goes to a black screem
SOURCE: "the hard disk's file system is corrupted and will be restored"
Ok, it appears that your hard drive in your PS3 is corrupt and needs to be reformatted. You can get an external hard drive enclosure and do it yourself. You would have to take the hard drive out of your PS3 and put it in the external hard drive enclosure and plug that into a computer with the supplied USB cable and format it. From what I'm reading out there, the external hard drive enclosure has to be for SATA 2.5" hard drive. You could probably replace the hard drive with a larger one just as easy if you wanted to. If you don't feel comfortable with any of this, then its probably repair shop time. I hope this helps.moreover,,Use your recovery disc to reinstall your operating system. This should clean up your hard drive and restore any missing or corrupt files.
SOURCE: My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
SOURCE: Playstation 3 hard drive problem
hi mate, your hd is broke, you could phone sony if its under warranty and they should replace it, or you can upgrade your hd to a 250 gb one, its very simple to do and the price of the unit is about 40 pound or about 80 dollars. Seagate is the best make to use, just google it.
SOURCE: hard disk's file system is corrupted
Hi if you have the ps3 with the model # cechh01 or cechk01 or cechl01 this happen a lot you need to install the new update in a usb memory card and follow the instructions on the ps3 go to sony for instructions on how to download the update in a removable usb if you have the older models you need to format the hard drive or install another one and format the old drive in another ps3 and this can fix your problem
SOURCE: hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
1. Turn off PlayStation 3.
2. Hold the power button down until the system turns on and then off once again.
3. Once the System has been shutdown, re-press power until you hear 2 consecutive beeps .When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
7. Choose to 'Restore File System' and follow the process through.
If that doesn't work you can try some of the other options.
