Our ImageRunner is networked and in a central location in our office. Every time I want to print an envelope or anything of size other than 8 1/2 x 11, I have to physically go to the printer and change the paper size and type then go back to my computer and print. Just selecting the right paper size/type on my computer doesn't work - the printer screams error until I go to it and make the changes on the unit itself. Our old ImageRunner adjusted automatically based on the computer print settings. Does anyone know how to set up the 1025if so I'm not having to go back and forth to the printer?
When you are printing something get to the print area and before pressing the print button click on printer properties and then select the paper size from the list available
save then press the print button
it is only good for the job you are printing as the next job , it will revert to the default setting
SOURCE: Paper sizing error
Solution #2 WORKS! Just when you use the #clear option.. select "ALL" it will reset everything but all you have to do is simply re set the paper size to letter as it seems to default to A4 size once it re-initializes. What a nightmare this was..
SOURCE: Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
SOURCE: My office has a CANON
In the cassette change the blue dial back to the correct type, either a4 or A4R (landscape). Sounds like you have to set it back to A4, Blue dial right hand side, front of cassette when you open it.
Or press the paper select button on the copy screen and see what it has been changed to, then change the dial in the cassette.
SOURCE: Fax L200 Check paper size problem
This is due to the reg sensor being worn, item 26 in the photo
please order and replace
RB2-1700-030 - LEVER, REGISTRATION SENSOR
hope this helps
SOURCE: How to set the date and time
Below are instructions for changing the Date and Time for your machine. At the end, you will find a link for the owners manual for the 2060. Best of luck.
Greg
Entering the Date and Time
Follow these steps to enter the date and time.
1. Open One-Touch Speed Dial panel.
2. Press Data Registration.
3. Press Set twice.
4. Press Set again, then use the numeric buttons to type in the correct
date and time.
Use the MM/DD/YY format for the date and use the 24-hour
clock for the time, so 2:30 p.m. would be 14:30, for example.
5. Press Set to save the date and time.
6. Press Stop to return to standby mode.
http://aaabusinesssystems.com/pdf/_2060_Users_Guide.pdf
