Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV4755AWW top load washer is leaking water badly. No leaks around the hoses, any ideas? Model good/worth having repaired?
6ya staff
SOURCE:
Jimster
James Greene
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
catriver
Ron Marek
  • 878 Answers
SOURCE: Maytag Performa Washer
Vitto, the fill hose for the tub is located up on top of the tub. Its a push in and I have on occasion see them come out or loose. You are going to have to pop the top to get a look at what is going on. First there will be 4 screws on the dispensor assy. each corner. Remove them and lift the cover. Next will be the door. Remove the hinge screws not from the door, but from the body. On the other side will be 2 spacers, remove them . Now lift the door up and off the washer. The front panel will now pull out and come off the 2 clips on the bottom. You will be able to see the bottom. Now there will be two angle clips on each side holding the top down. Remove the screws, clips and the top will lift up. Now you will be able to place the door back on with out screwing it back on and close it. Start a cycle and now you will be able to observe the top hoses and bottom pump and hoses. Identify where the leak is and put this deal behind you. This is an easy gig, just take your time. Catriver.
Posted on Dec 05, 2007
Anonymous
SOURCE: Large leak during wash cycle---Maytag - model LAT9520AAE top load washer
hey guys i guess this is not a uncommon problem. I have a commercial washer about 4 years old that get moderate service at a rental of mine and it is leaking from the tub as well. I hope to fix the problem because the new machines are very expensive.
Posted on Sep 08, 2008
Anonymous
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
Anonymous
  • 115 Answers
SOURCE: Washer leaking when filling up tub
i dont know what he is talking about and the leak on that machine I am 99% sure you just need a new pump it leaks out the center of the pump where it goes on the motor shaft just lean it back take off the 2 clamps on the pump slide it off the motor and then take your hoses off it then just reverse it with a new pump
Posted on Jan 01, 2009
Maytag neptune top load fav6800aww washer leaks from bottom during spin
for a start you should check if the rubber of the spinner is still ok. you will probable have to replace that rubber
Mar 21, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Washer Model LAT9416AAE - Top tub seal is leaking or where the tub and the shaft meet is leaking. What would the cost be for parts and repair (service fees, labor, etc.)?
The usual charge when i have repaired that is around $375
in addation to the seal a tub bearing would be required since the seal has leaked it very likely has rusted the bearing. To replace those both the inner and outer tub have to come apart,the breakdown would be
Parts--$150
Service Fee $75
Labor $100
labor and service fees vary from company to company and that is probably low,yet it is a great washer and may be well worth investing in to repair
Aug 06, 2011 | Maytag LAT3600A Top Load Washer
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Nov 15, 2010 | Maytag SAV5710 Top Load Washer
Leaking water
When your Maytag top load washing machine leaks water, you will need to check the following parts until you find where the leak is coming from.
The water valve: The first place you need to check is behind the washer. Check the two fill hoses and the water mixing valve.
Check for pinholes or cracks on the plastic body of water mixing valve.
Remove the front panel : The next thing you need to do, is to remove the front panel so you could see the tub and the hoses.
Set the washer on the regular cycle and turn it on so it could start filling.
Use a drop light and check all the hoses under the washer as the washer is filling.
Make sure to keep your hands away from any moving parts.
The pump : If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag washing machine to leak water.
The stem & seal : Another place that the washer could leak water from, is the stem & seal on the holding tank.
When washer leaks water from the stem & seal, the water will leak down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110.
Apr 19, 2010 | Maytag PAV2300 Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
We have a maytag top lod washing machine model
Hi, the actual drain pump may have a crack on the housing. i would inspect this possible issue just to confirm that the pump structure if well.
Secondly, there may be a slight rupture in the tub seal. you will need to disassemble the tub to get a good look at this possible leak point. this is an uncommon area for leakage but, it is possible that the water is leaking from this area.
Last, i would check the water inlet valves for cracks. this is another uncommon issue but, its worth checking during the inspection.
Jul 10, 2009 | Maytag Washing Machines
My top load maytag leaks from the bottom during wash cycle
90% chance it's just a loose hose or a bad fitting/clamp. Very cheap and easy to fix. If you like your washer, I'd say either pay to have someone come repair it, or if you are handy (or have a handy friend) give it a try yourself. You'll have to remove the back and find the leak.
Jun 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Top Load Maytag Neptune Washer
hello i am a appliance repair man. do you was a lot of sandy cloths? what is happened is your seals are bad on the washer. i bet the sales men told you when you bought it that you could fill it plum full. its not true. i have seen this machine in and out of my shop so many times its not funny. by the way if you do fix it please put a surge protector on your machine. trust me it will save you more headaches. if you have any more questions feel free to email me at weltmister1234@yahoo.com. next time you buy an appliance call a repair man and ask them what kind of problems that the appliance has first.
Nov 08, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
159 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
