Question about Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Closed captions Hi, recently I bought (for a very good price) very lightly used Toshiba MW27FN1 TV, DVD ,VCR combo unit. We are very pleased with picture and sound, but for some unknown reason I can't turn closed captions ( cc ) on. This TV set is connected to a satellite receiver so signal strength and quality is more then good. Before I've had a very simple Sanyo 25" TV set hooked up to the same receiver and never had a problem with closed captions. TV is connected via RCA cable and signal is on Line 1. When I press closed caption button on my remote control it shows closed captions ch1 or ch2 and text ch1 or ch2, but no captions will be shown on the screen. I know captions should be on "closed captions ch1" , and there is usually a few seconds time delay after cc are turned on. Also I know that not every program or movie has closed captioning available, so I made sure the cc is available on program I tried to turn cc on. I?ve tried different connections via coaxial cable and couple another things but nothing helped. I don't know if its something with cc decoder inside the TV or what. Like I already said my old TV shows cc in same place without any problems. I hope somebody can help. Thanks. peteroctober.
  • replysam Oct 06, 2008
    i have a problem.i have a univcesal remote and have no clue how ot set the cc on..
  • carolsib Feb 01, 2009
    I cannot get rid of the close caption feature on my toshiba tv/dvd combo. both caption feature,shows that they are off.please help if you can
Closed Caption may only come on when you have the television muted.
Posted on May 28, 2008
6ya staff
SOURCE:
My cable remote will not turn my Toshiba MW27FN1 TV/VCR/DVD combo off and the buttons on my tv do not work
That is an issue for your cable company to resolve. You rent their gear so it has to work since you are paying them good money for rental. Make them earn it.
Aug 25, 2017 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
THE DVD WON'T OPEN OR PLAY ON MY TOSHIBA TV/VCR/DVD COMBO MW27FN1
check either the front or back of television for a small pinhole, that should be the emergency eject hole, place unwound paper clip in hole to eject disk, however, this will probably be re-occuring and dvd player will need to be replaced.
Oct 17, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
White lines at top of screen - can't make go away
You have a problem in the vertical output circuit. Check for bad capacitors around the vertical output IC. The value of these caps are marked on the side of them. Thanks for using fixya. Please take a moment and rate this responce.
Nov 30, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Feb 03, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
DVD PLAYER WON'T OPEN
Do you see the open close icon ont the screen? Do you hear any motors running? Most common problem for this is the mech jumps time
Jun 17, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Cable issue
No its in the menu. You have to use the remote to auto program the unit
May 24, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
I recently bought a new DVD/VCR machine. The VCR is the problem, tapes are jumpy, many lines across the screen and close captions are distorted. EVen just watching TV without tape or DVD, close captions...
Hi Carrie
Not to worry, son-in-laws are good!
Assuming the machine is working correctly, there is only one reason why the picture will be distorted and that is interference.
Here are a couple of things your son-in-law may be able to check for you.
Firstly, make sure that the DVD/VCR is connected to the television using a scart lead. The DVD/VCR was probably supplied with one. It is a short cable with a large rectangular connector at each end.
If a scart lead is already being used, there may be other units connected to the tv that are causing interference. Try removing all the other units like cable tv, satellite receivers etc and see if the DVD/VCR is any better when it is the only unit connected to the tv. If it is, you will need to use a scart selector box so you can switch each unit connected to the tv separately. (Sorry I know it's getting confusing now!)
If it still isn't any better, ask you son-in-law to check through the menu on the DVD/VCR and look for a setting for Video Format. This should be set to PAL Format unless you are in North America in which case it should be set to NTSC Format.
Hope this helps, please feel free to ask me for more info if you still have problems.
Regards
Helen
Mar 13, 2008 | Televison & Video
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
I can not get a TV signal to work with the Toshiba through coax.
bill24 sorry to be the one to tell ya but you need to go into setup on the tv to setup the channels in the menu and the memory and the only way is to do it with an original remote. BUT your in LUCK. http://remotes.com or 1-800- remotes has the remote you need for $27.38 + shipping. Good Luck
May 27, 2006 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba MW27FN1 27 in. TV/VCR/DVD Combo Logo
396 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
