Question about Sansui HDLCD1908 19 in. LCD TV
Sansui HDLCD1908B Television
I have a Sansui HDLCD1908B television. When I hook it up to cable and try to get digital channels I receive a black screen that says "Digital channel signal strength is low". I have hooked this television up to other cable jacks in the home that I know work correctly and I still receive the same message. Help!
  • 1,238 Answers
Call you digital cable provider
Posted on Jul 23, 2012
4 Suggested Answers
6ya staff
SOURCE:
Bob Citizen
  • 520 Answers
SOURCE: Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Posted on Jan 07, 2009
Bob Citizen
  • 520 Answers
SOURCE: Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Posted on Nov 05, 2008
Anonymous
SOURCE: How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Posted on Jun 06, 2009
I'm trying to hook up a 19" Sansui tv. I'm not on cable, but tried hooking it up to an antenna without any luck. What do I need to do to get the TV to work???
Make sure the TV can receive digital over the air signals (it should have an ATSC tuner), that is it doesn't need a digital converter box. In the menu settings make sure the TV is set to antenna, not cable. You should be able to use the auto-scan (auto-program, etc.) from the menu to find and program the local channels.
Feb 02, 2016 | Sansui Televison & Video
My TV picture is not coming in and neither is all my channels.
Perhaps you have the TV set to receive analogue TV rather than digital (DBV). Consult the manual about receiving a digital signal.
Jan 21, 2014 | Sansui 19 in. LCD TV
Have a cable box on 19inch lcd sansui, and can't recieve my digital channels?
Is it supported by the TV? Are you licensed to receive the Digital channels, i.e., is it a payable channel?
Aug 16, 2012 | Goodmans GTVL19W17HDF 19 in. LCD TV
My tv says "digital channel signal strength is
On the tv remote look for Mode Select, move switch to TV then "03" then press enter. Then pick up cable remote make sure the "cable button lights up ( by pressing on cable button at top) then you press guide...Voila!
Sep 14, 2011 | Sansui HDLCD-4212 LCD TV
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
Jan 01, 2011 | Sansui HDLCD-1900 19 in. LCD Television
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
When I turn on tv the screen is black and my set is LCD/plasma
try a video source using the video in ports...so that you can isolate if it's the tv problem or the cable device
Aug 11, 2009 | Sansui DTV2760 27" TV
Toshiba vcr doesn't recoganize digital from sansui tv
is your vcr hooked up to your t.v. or through your cable or satelite box? if to t.v.,hook up through your cable or satelite receiver and this should solve your problem.... and should you need help with connecting cables to a receiver i can help you with that as well... i hope this was helpful...
Dec 16, 2008 | Sansui DFTC2000 20" TV
Analog/Digital
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui HDLCD1908 19 in. LCD TV Logo
553 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
