Whirlpool AWM8121 Washing Machine - stops working, Flashing lights on Rince, Start & 0 speed. Pump pumps water out to drain, Plays up on all wash cycle I commonly use - Rapid, Colour & White. have tyied some of the other cycles and still plays up.
I replaced the Water level sensor which didn't fix it.
Washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
It also has the problem on the wash cycle Flashing lights on Wash, Start & 0 speed. Pump pumps water out to drain.
Ditto - exact same issue. I've cleaned the filter but still no-go.
I think it may be tied in with the pumping process at the end of each cycle but I'm not sure....
I'd be glad to get any help!
