1, CD must be upside down in the cartridge
2. if that doesnt help then the LENS itself may have fallen out of the reader assembly. I've seen this happen twice on Pioneer players
The player have problem with the laser pickup unit.
Try one thing, there is a disc available for cleaning the laser pickup unit (). You will get in any cd shops(instructions will come with it). Buy the cd and the insert it in any one of the tray. It will clean the laser unit if there is any dust in it. After cleaning put a disc and check is the problem remains. If the problem remains the you have to change the laser pick up unit. You can fin a link here which will lead you to the laser pick up unit. You will get the part only against confirm order.
PEA1030
Laser cleaning CD
Ajin
SOURCE: Pioneer PD-F1007
Hi, You need to check for schematics of the changer. They are sold in various places. Daniel
SOURCE: Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
SOURCE: Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
SOURCE: my Pioneer PD - F606 25 disc player will load a
In any CD player/changer, this issue is often the result of either the CD itself or the laser optic being in need of cleaning. You can actually clean the CD by using your hands or a soft lint-free cloth and wash in dish soap and slightly warm water, then rinse. If the optic itself needs the cleaning, you can buy a kit at any stereo shop or Radio Shack. I would start with the CD and then clean the optic if necessary.
