Question about Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer
How to reset samsung washing machine
It is not working automatically but individually wash, soak, rinse and spin is happening. i think the operating software is malfunctionning
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
My machine is going slow is not washing clothes
Posted on Mar 23, 2019
    New Friend:
Http://www.samsung.com/us/support/owners/product/WA5451ANW/XAA
Posted on Feb 29, 2016
6ya staff
SOURCE:
Jjet
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
Roger Miller
  • 714 Answers
SOURCE: water not leaving machine
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 17, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Posted on Dec 11, 2010
lolx259
SOURCE: My Samsung Washing Machine (Diamond Drum model) problem
You probably did not save the mode you want. See the information booklet provided on how to set the mode.
Posted on Oct 29, 2010
Anonymous
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
I have probelm in my Samsung washing machine WF-B1061
NF and 4E = No Water Feed = Washer Not Filling. This means that there is an issue that is preventing your washer from receiving water into the water inlet valve. The troubleshooting steps below apply to all types of Samsung washing machines including front load, top load, and washer and dryer combos
https://removeandreplace.com/2015/12/16/samsung-washing-machine-shows-nf-or-4e-error-code-what-does-this-fault-code-mean
Sep 17, 2018 | Samsung Washing Machines
My samsung washing machine WA40J3000A is not spinning. Everything else works but it does not spin during wash, rinse or spin cycle.
if you can hear the motor running on spin or rinse then the clutch is not working if you cannot hear the motor then the motor is not working.
Feb 28, 2018 | Samsung Washing Machines
Error code F51-when performing the Rotor Position Sensor manual test, the hall sensors light up the indicators when I rotate the basket.
Bruce:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 07, 2018 | Whirlpool WTW6400SW Cabrio Washer
Model 9156200 top loading washing machine
the lid switch may be loose or broken it happens to me it was washing but never rinse i found out that it was a loose switch this switch prevents the rinse cycle from working with the lid open because of the high speed rinse ,some machines dont work at all, a loose switch makes the machine think the lid is open even if it is closed.good luck.
Apr 16, 2014 | Kenmore Washing Machines
Supra top load washing machine, model SW5BS2P, operating manual
It won't not automatic rinse and spin now to fix? Reset? How?
Aug 27, 2013 | Supra Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Mar 21, 2010 | Siemens WFXD5202UC Washer
Kenmore machine won't do more than fill on SOAK setting;won't run
I'm unsure how the normal operation was restored. I attempted to correct it by setting the machine to SOAK+PREWASH overnight to assure that the SOAK timer had run out. Then My wife (who never uses SOAK or PREWASH options) made a clockwise trip around the TIMER control stopping at each of the "detents" (I did not witness this) one of the spin entry points worked to empty the washwater and the NORMAL wash cycle resumed normal function.
I'm not confident that my description above contains all the essential information needed to correct this problem and am disappointed that
I cannot find SUPPORTING LITERATURE that shows how to use these alternate cycles and combinations without another hang-up like these two that I have experienced. That which is supplied with the washer is pathetically inadequate and the Sears site has little else to offer. Document #8566913 was not delivered with the machine but I did find it somewhare on the INTERNET printed parts of it for additional help. *ALERT* #1: Just now I discovered that it does cover the Model series 110.2692* of which my machine is part ... and it ALONE warns of the 20 minute mandatory wait when two controls are set to obtain SOAK+PREWASH function.
*ALERT* #2: Last nite I discovered that the lid switch makes NO SOUND when the lid is lowered normally but can be made to click by pressing on the left rear of the lid. Feeling under the lid, I found no switchpad (?) on the operating arm as shown in diagrams found elsewhere.
FINAL QUESTIONS: 1) could failure to FULLY operate the lid switch allow partial function of this machine, e.g. to fill, agitate, rinse and spin normally but not to soak or prewash? 2) can anyone direct me to a place where I can obtain breakdown diagrams repair directions for this machine?
Dec 28, 2009 | Kenmore Washing Machines
Washes but does not rinse or spin . I think the pump is not working, it is not draining the water out of the washer which is causing the rinse or the spin to work would it be a switch or the pump
After wash the water drains out of machine automatically but its not drainout means the drain motor is not working properly or proper power supply is not given to the drain motor
Dec 22, 2009 | Washing Machines
Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer Logo
22,233 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
