I don't know where or what to use for a speaker or headphone. I'de love some sound on my computer...
You need to add some information - what is the source for the video that you are viewing on the VA520? The VA520 has no speakers in it. If it is a desktop computer, look on the back of the computer for a green 3.5 mm stereo audio port. This is your speaker out connection. Plug in any set of computer speakers or headphones. (Computer speakers may require a USB connection or to be plugged into an AC outlet to power the speakers.) You can find cheap speakers for under $20; good speakers will be more expensive. With a laptop or some desktops, you'll find a headphone jack on the front of the computer. (This will be labeled with a small picture of a set of headphones.) The headphone jack is also a 3.5 mm stereo port.
I hope this helps.
(laptops usually have internal speakers; most desktops do not have any internal speaker anymore. If you have headphones with RCA audio plugs, you can use a RCA F/F to 3.5 mm M audio adapter to use them with the computer. A stereo system may not work with a computer.)
SOURCE: VA520 Resolution Message
Have you tried via the Control Panel/Display function? The driver provides the means but Windows provides access to those settings.
SOURCE: Upgraded OS to Windows 7. Now can only get
The problem is not at your monitor, it's on the VGA card; there are no drivers installed. Clarify me the brand / model of your VGA (or in case of embeded at the motherboard post the motherboard's brand / model) in order to try to locate and post you back the drivers for Windows 7.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
