2005 Renault Kangoo 1.9 Logo
BRian Posted on Jul 24, 2012
Radio on kangoo column controls not working
Radio display has stopped working as well as column control radioi still working
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Jul 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
Helped
7143
Points
58
5 Related Answers
Anonymous
  • 388 Answers
  • Posted on Mar 17, 2011
SOURCE: My renault kangoo van radio/cd player has stopped
If the battery went dead or the radio lost power at any time you will need to re-enter the code for it to work again. If this is not the case check the fuse for it as it may have blown in which case you will be required to enter the radio code after replacing the fuse.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 01, 2008
SOURCE: renault kangoo radio codes
The code is in the owners manual package that came with the car, if you don't have that you will need to contact the new car dealer, he is the only one that can help with getting the correct code.
xxxxxx xxx
  • 5117 Answers
  • Posted on Sep 06, 2009
SOURCE: help, need the security code for renault kangoo van
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also confirm  the MAKE of CAR it is fitted into.
RixsFixes
Radio Code Pro
  • 2200 Answers
  • Posted on Nov 27, 2010
SOURCE: radio code needed for renault kangoo
Please view this FixYa Tip which outlines the correct and exact procedure to enter the radio code for Renault. There is also a recommendation for a cheap way to obtain the code you require and reactivate the radio.
Thanks for using FixYa.
Anonymous
  • 33 Answers
  • Posted on Jan 13, 2011
SOURCE: Hi, my mechanic disconnect the
The easiest and best way is to take it the nearest renault dealer and for a small charge if any they'll take your vin (vehicle identification number) and give you a code which can be used indefinitely until a new radio is fitted. This process takes about 5 mins and to input the code press number 1 the amount of times till the first digit of the code appears and the same which number 2,3 and 4. Finally press and hold button 6 till a beep confirms correct code.
Alternatively you can get the code yourself through certain websites but probably be more expensive.
Whats your vin (chassis number) and il see about getting a code if i can.
Hope this helps
2answers
2016 chevy sonic steering wheel controls will not work. Horn works. Any ideas?
check fuses and relays connections--check column harness wiring / connections with a meter --clockspring failure--switch failure
2002 Mazda Protege ES Car Radio and audio controls don't work
Have you done anything to troubleshoot, such as pulling the radio and checking for power to the appropriate wires? Is this the original radio or is it an aftermarket radio? Have you considered installing an aftermarket radio? You could probably pick up an inexpensive aftermarket radio for less than finding a good original radio if you're comfortable with doing the wiring and installation. But even if you go the aftermarket route you'll want to confirm the correct voltages are getting to the radio and that the grounds are good.
-Rod
2002 volvo s80. My radio display lights stop working so I can't see the radio but it still works and the stearing wheel radio controls stopped working cruise still works though what could cause that
the wiring from the wheel controls may have come loose at a connector so i'd try making sure all connetors are pushed home , even behind radio , have you had any work done recently to the vehicle ?
Why is it on stearing wheel the buttens of the cruise controls and radio do not work but it did work before it is on the volvo v70 2003 model
there is what is called a clock switch located under the steering wheel that must have went kaput. it is what transfers the signal to the steering column.
Radio flashes on and off and no panel buttons work.only the steering column controls work.
Try pulling the audio fuse out for at least 10 seconds and then plug it back in and see if that helps. Doing this resets the radio sometimes they "lock up"
I need a wiring diagram for the IPC in a 2004 Cadillac Deville. Trying to troubleshoot a U0155 OBDII code. The symptom is that my climate control display only shows LED's intermittantly. All of the...
Do you know what U code's are for ? How did you pull this code ? There is no U0155 , U code's start at
Diagnostic Trouble Code (DTC) List
DTC
Diagnostic Procedure
Modules
U1000
DTC U1000 and U1255
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC, IPM, LMDM, LRDM, MSM, PCM, Radio, Remote Playback Device CD Changer, RCDLR, RIM, RMDM, RRDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1016
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC , IPM, LMDM, LRDM, MSM, Radio, RCDLR, RIM, RRDM, RMDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1040
DTC U1001-U1254
IPC, PCM, SDM
U1056
DTC U1001-U1254
EBCM, PCM
U1064
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC, IPM, LMDM, LRDM, MSM, PCM, Radio, RCDLR, Remote Playback Device CD Changer, RIM, RMDM, RRDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1065
DTC U1001-U1254
DDM, DIM, ESC, FPDM, IPC, LMDM, LRDM, VCIM, HVAC Control Module - Auxiliary, PCM, Radio, RIM, RMDM, RRDM, VCIM
U1066
DTC U1001-U1254
DDM, FPDM, IPC, IPM, PCM
U1088
DTC U1001-U1254
IPC
U1096
DTC U1001-U1254
PCM, SDM
U1128
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, Digital Radio Receiver, Remote Playback Device CD Changer, VCIM
U1129
DTC U1001-U1254
Radio
U1130
DTC U1001-U1254
Radio
U1137
DTC U1001-U1254
Radio
U1144
DTC U1001-U1254
IPC, Radio
U1151
DTC U1001-U1254
Radio
U1160
DTC U1001-U1254
IPC, RIM
U1161
DTC U1001-U1254
IPC, RIM
U1162
DTC U1001-U1254
IPC, RIM
U1163
DTC U1001-U1254
IPC, RIM
U1164
DTC U1001-U1254
DDM, Digital Radio Receiver, DIM, FPDM, IPC, LRDM, MSM, VCIM, Radio, RIM, RRDM, Steering Column Module
U1165
DTC U1001-U1254
DDM, FPDM, LRDM, RRDM
U1176
DTC U1001-U1254
IPC
U1192
DTC U1001-U1254
IPC, PCM
U1255
DTC U1000 and U1255
U1300
DTC U1300, U1301, or U1305
U1301
U1305
The data link connector (DLC) allows a scan tool to communicate with the class 2 serial data line. The serial data line is the means by which the microprocessor-controlled modules in the vehicle communicate with each other. Once the scan tool is connected to the class 2 serial data line through the DLC, the scan tool can be used to monitor each module for diagnostic purposes and to check for diagnostic trouble codes (DTCs). Class 2 serial data is transmitted on a single wire at an average of 10.4 kbps. This value is an average; class 2 uses a variable pulse width modulation to carry data and depending on the message it may operate faster or slower. The bus will float at a nominal 7 volts during normal operation. Each module can pull this lower during the transmission. The bus is not at battery positive voltage or ground potential during normal operation. When the ignition switch is in RUN, each module communicating on the class 2 serial data line sends a state of health (SOH) message every 2 seconds to ensure that the module is operating properly. When a module stops communicating on the class 2 serial data line, for example, if the module loses power or ground, the SOH message it normally sends on the data line every 2 seconds disappears. Other modules on the class 2 serial data line, which expect to receive that SOH message, detect its absence; those modules in turn set an internal DTC associated with the loss of SOH of the non-communicating module. The DTC is unique to the module which is not communicating; for example, when the inflatable restraint sensing and diagnostic module (SDM) SOH message disappears, several modules set DTC U1088. Note that a loss of serial data DTC does not normally represent a failure of the module that set it.
Your best bet ,take it to a qualified repair shop.
If i have a radio controlled steering column with floor shift can i use a 97 steering column without radio control
should not be an issue. the wiring connector for the radio control is on a seperate wiring harness, and will just be left abandoned. all the other wiring should be the same. good luck!
Radio/CD controls don't work
check to see if it is geting power and if it is then get a new one
4helpful
The cruise control in my 2005 Ford Freestar just stopped working yesterday, then this afternoon the radio controls in the steering column stopped working as well
clock spring in the steering column is my guess. They are delicate and have to do with anything in the steering wheel like airbag, horn, or anything that is operated by buttons on the wheel. These wires have to turn constantly with the steering wheel and the "clock spring" goes bad often enough
1helpful
The tuner is gone in my OE radio. Will a PY520 replace my OE radio and work with my steering wheel controls?
if the connector is the same then you should be able to use it however it may require programming
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Renault Expert? Answer questions, earn points and help others
