Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Anonymous Posted on Jul 24, 2012
Plrs267za don't work
Pam Jackson
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2015
Pam Jackson
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
165
Points
Motor is not working. How much to repair
  • Official Brand Answer 4,342 Answers
  • Posted on Jul 26, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467897
Points
5907
What is it doing, or not doing? Any alpha-numeric error codes or flashing lights?
2007 chrysler town & country has a rough idle but drives smooth what could it be
If it idles rough it runs rough,you just don't
notice it
You can start anywhere you want
If you haven't changed spark plugs in 3 years do that
Replace any front or upstream O2 Sensors over 100,000 miles
Check fuel pressure,tps sensor voltages,check for loose air
filter cover,vacuum leaks,loose O2 sensor,just go thru the
entire engine,it obviously needs work & I will bet it hasn't seen
much & you don't know what is done when you ask & pay
for work.
May sound harsh but many shops aren't there to resolve problems,
they throw on as many parts as the people on this site do at home,
from the questions is see here,dealers guess as well and don't road
test,kind of sad really
How to make timing of chevrolet engine 2005 model, and to make sure the correct position of camshaft from rh bank to lh bank of the cylinder head,,,,pls send me an xerox for the camshaft position
You don't start a job like that, without factory manuals
or buying a timing chain & belt manual
We don't have anything to give you
We found & use the site the same as you, from home,
don't work for site
How to charge a/c system
You don't actually charge it
Your referring to adding to a system ,that
doesn't work & is leaking & poluting the atmosphere
So to add,is to be irresponsible
You need a qualified a/c technician,to find & repair
any leaks
Then it is evacuted with a vacuum pump & checked
again in a vauum for leaks vs: under pressure as in
the beginning
Then the refrigerent is entered under a vacuum
(charged) in oz's with a scale,so you don't overcharge
So you see, without the knowledge & proper equipment,
you can not properly work on any A/C system,roof top,
commercial,window unit,refrigerator,etc.
2answers
Slip going into senend
Once the transmission slips it is done and needs to be rebuilt..
1helpful
Rear brakes are noisy while driving
The job wasn't done correctly,that is obvious
Most places don't remove any rust so parts slide
as they should ,nor do they lube anything
I have worked on brakes for 50 years come july & never
had a noise or hot,no issues
When you say changed out,that's what you got
It is called hanging pads,slap them on & done.
You have brake hoses & claipers to consider,parking
function,etc
If they don't release for some reason,you have heat & noise
Sloppy work
Hooked up a cd player to my 2005moms grand am but volume don't work? Why?
Check to make sure it is not manually muted, if that doesn't work make sure your speaker wires are connected properly in the back of the radio and speakers work also. If it is run through an amplifier, make sure the amp works and the speaker wires are connected properly too! Don't forget to check gain on the amp too!
My 2002 Grand Prix sounds fine upon starting. When I get to 45 mph, it starts to sound as if it's working harder. It's like a loud hum starts and gets louder as it goes up to 60 mph. As I decrease...
Front Wheel Bearing Hub
You will have to remove the brake calipers,hang it,&
remove the rotor,then you can turn the hub & feel the
roughness.
ROCK AUTO.com for parts & look at that hub, so you
match it up the same. Don't get in love with one brand
you like, if the hub looks different at the back where the
speed sensor goes in
You also may find your self buying a torx socket or metric
socket driver to get the speed sensor out. Maybe not
If tools are needed,do yourself a favor & step inside a Snap-On
Truck & just buy one item or so. If you don't ,you won't find those
items anywhere
1helpful
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
