My coin op washer won't start. I checked coin slide and manually depressed start button. But it would not start and the "in use" light would not turn on. I did check that power was on and inside the control box a red LED light is flashing, indicating power is on. What do you think is causing the machine not to start and how can I fix it?
SOURCE: Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
SOURCE: Draining water from inside through center.
The tub seal kit is $85 USD, You will also need a drive bell kit$23 USD, you should replace the upper bearing $?, for a complete rebuilt I would also replace the brake pads all three, and the belt, maybe the pump if it doesnt come off easily. Plus what you break taking it apart, so we are looking @ least $150.
Yes you can do it yourself, you dont need the tub wrench if you can borrow a deep socket, its the drive bell seal tool you really need.
Please let me know if you have additional questions. the serial number will tell you the age first two digits are year next two are month, starts with and R, built in Ripon WI.
SOURCE: i just got ean speed
Have you checked the receptacle? Plug a light or something into the receptacle to see if it works.
SOURCE: The soap dispenser in my
This is usually caused by a low water pressure problem.Water will take the path of least resistance and in this case the soapdispenser suffers. A couple of things to look for are.
To check this remove the hot andcold fill hoses on the rear of the machine. Look inside of the water valve forand debris there is a screen on the valve to catch this. The machine also camewith inline water screens. Check to see if theses were installed and if theyare plugged and installed properly.
These will be inside the fill hoseat either the machine end or the spigot end it depends on who installed them.The proper orientation of this screen is that the pointed end should be facingthe incoming water.
2. Check to see if you have goodwater pressure at the machine hose connections. This is easily done with awater pressure gauge. I purchased one at Home Depot for around $10.00. This ismuch less than a service call. Put the gauge on the water line and turn on thevalve. Then turn on any faucets or appliances that feed from the same line andsee what the pressure is. The installation manual that came with your machinewill have the water pressure spec on it.
SOURCE: Hi, I have a Speed
This is a door lock error. The control is not seeing that the door was locked.
Try pushing the door closed where the door strike is. If this does not work you may nee to adjust the door strike.
