Just bought Kenmore bottom freezer refrig (bottom freezer with in-door water/ice). Manual says to change filer when "indicator light" goes on... but where is that light? Also where is the "shutoff valve" we need to turn off when changing filter?
Change water filter on my Kenmore Elite double doors and freeze on bottom. The light red light was on change filter. We changed it and it is still on
The indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter.
also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic.
by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
