Took the fan off for cleaning. Husband says it blows in to cool and I says it blows out to pull hot air away from unit. Help please.
SOURCE: panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
SOURCE: Panasonic dmr-eh57 multi-region unlock code
I sent an e-mail to Panasonic New Zealand to ask about this, and they advised:
"Panasonic NZ no longer pre set DVD recorders or players
for all region multi-zones.
However, we will multi-zone for all
regions on request.
This needs to be done by an
Authorised Service Centre, as a special service remote is
used.
Once delivered to one of these
agents, the service company will charge the fee to Panasonic
NZ."
If you're not in NZ, try contacting Panasonic in your own country. Just call up www.panasonic with your country code after eg. US = .com and NZ = .co.nz. It seems a *lot* easier than all those complicated hacks on the net. Now all I have to do is work out how to disconnect my DVD recorder again, and try to
PS. I realise this question is 11 months old by now, but I hope my response helps someone like me just cruising the internet looking for help.
SOURCE: PANASONIC DMR-EX768 DISPLAYS MESSAGE EXT-L
Hopefully you will have figured this out by now but you have accidentally turned on the external link function (used to automatically record from a sky box or similar) - simply press the ext-l button on the remote (second row from the bottom of the remote, 3rd button from left) to turn it off again and everything will work normally once more.
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Derived from p.54 of the owners manual
Press [SETUP] to show menus
Select "Display" (6th line down or 2nd from bottom)
Select "Language" (2nd line down)
Complete owners manual @:
