I see you have a few kvt 815 dvd's. i have a kvt 715 and have the wiring manual. but i have a yellow wire and a blue from the brain and my pdf manual dose not show where they go can you look at your factory manual and see where they go ? they should be the same. thanks, [email protected]
SOURCE: forgot my password on my kvt 715 help me please
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: kenwood kvt 715
All of the Compatible Kenwood Units will have Bluetooth Printed on the Face in Small Letters. If yours Does not, Go to Crutchfield.com and they will have the Connectors that you need for this to be done. Please Rate My Response! Thanks!
