eBayhttps://www.ebay.com > ... > Carburetor Parts
Find many great new & used options and get the best deals for Carburetor Rebuild Repair Kit For Husqvarna YTH22V42LS Lawn Tractor at the best online prices ...
US$21.99 · In stock
Larry,Carburetor may be dirty, remove and clean or rebuild. Check the attached links,videos,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Husqvarna Chainsaw 235Troubleshooting Repair Help
If spark is ok then I would say the carburetor is the likely problem or the fuel is not entering the engine. Something like the following instructions might help. How to Adjust Husqvarna Carburetor eHow
Both H and L screws should be set 1-1/2 turns out from stop. Turn the idle speed screw two turns in from where it is now. When you had the carburetor apart, did the rubber diaphragm seem hard? If it did, re-kit the unit. When you clean the carburetor body, use spray carburetor cleaner and use compressed air to blow out all fuel passages including the two mixture control screw holes. Be sure to check the condition of the fuel line and the air cleaner. Even a plugged muffler can cause weird problems.
