SOURCE: My Washer is saying pause no matter which cycle I
Hello, Thank You for using FixYa. I will be helping you today.Try unplugging it for ten minutes.
Thank You and please rate my answer if it was helpful..
SOURCE: Frigidaire Washer stuck on pause
does the unit have standing water still in it.if so use a shop vac and attach it to the end of the drain hoseand removed all the water the check you drain pump for any kind of foriegn object that may be stopping the impellar wheel.the door lock may also be bad, the last but maybe the first thing is a bad control board
SOURCE: Won't drain. Blinking pause. Won't
Hi.
You need to check the drain filter, which is directly connected to the pump. That is the place where you usually find blockage. The filter or coin trap is located inside the drum. See the schematic below:
If that is not enough, then the drain pump access is located in the front side of the machine, hidden behind the trim at the base. The kick panel is held to the washer's frame by screws:
After removing the panel you will Be able to access the pump. Have a container ready to collect water that will come out through the hose.
DISCONNECT POWER before starting the job.
Here parts diagrams: GLTF2940FS1 - parts catalog
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
SOURCE: Frigidaire Affinity keeps pausing mid cycle.
there is an access panel on the back of the unit. 6 screws and on the bottom is a rubber hose that comes from the tub. inside that rubber hose is a filter cup. i have the same unit and mine did the same thing. took it out pulled clog out put it back together. works like a charm. hard to get at but you can do it. use a drill with a phillips head to make it quicker. Also have pliers and a pair of channel locks. Good luck and it aint the Timer TRUST ME
SOURCE: My Frigidaire gallery front load washer won't spin or drain
its ether the transmission or the motor gone bad
Hello friend, thank you for your post!
I see that your Frigidaire washer, FAFW3517KW, is constantly showing you pause, when you press start it flashes the pause again, and that the door lock light does not come on. You could be seeing a couple of different possible reasons this is happening such as your control panel, door lock assembly, or door switch. Since it could be any of the underlying issues I would recommend having a professional come out to the home and repair the washer. -Matt
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS
SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL
WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL
WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS
ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE
ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH
SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM
AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND
PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS
LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER
THAN NINE: A=10 B=11 C=12
D=13 E=14 F=15
"EXAMPLE CODE F1: THE FIRST
DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A
WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN
TIMES AND THE START INDICATOR LIGHT WOULD
WAIT 5 SECONDS.
SIMULTANEOUSLY.
SERIAL
AS
D=13 E=14 F=15
To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons
simultaneously
Ail LEDs will go blank and after a few
seconds the control will signal the stored code using audible beeps and
blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons
are pressed.
A two-second pause between repeats affords you the ability to make accurate
counts to identify the correct error
codes.
You may also have a code
such as E47 or E24 etc..
Comme
back with the code and I will explain what is
the meaning of the code
