Samsung HLP4663W 46" Rear Projection HDTV Logo
Samsung hl-p4663w sound but no picture. light works
Bought a second hand Samsung hl-p4663w. Worked for two days then all of a sudden, there is sound but no picture. I can see the bulb lit in the back of the TV. TV responds to remote control commands like volume, channel and on/off. On power up, the menu on front cycles up, pauses at lamp, then no lights are displayed. Nothing blinking. Thanks for any help.
4 Related Answers
A
Anonymous
  • Posted on Apr 02, 2008
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Anonymous
  • 668 Answers
  • Posted on Jun 29, 2009
SOURCE: No picture on a Samsung HL-P4663W, trouble lights confusing...
The most common blink code for the Standby/Temp LED is the Temp Sensor and or Actuator Board. You can confirm which on by jumping the CN106 connector on the Actuator board. If the set works now, the Temp Sensor must be replaced. If it doesn't work, the Actuator Board would need to be replaced. If you are not familiar with the chassis or electronics at all , I do not recommend trying to fix it, call a professional. Don't take the chance of damaging it further.
I hope this helps,
Skyassoc
Anonymous
  • 17 Answers
  • Posted on Jul 11, 2009
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Anonymous
  • 458 Answers
  • Posted on Aug 13, 2009
SOURCE: samsung hl-r6178w 3 blinking lights
check you lamp door switch.check lamp drvier board has 310 v ? if no may be power board bad if 310 v ok may be main board bad .
2helpful
2answers
I have a SAMSUNG 46" DLP HL-P4663w, No picture but have sound. All three lights are flashing at on/off button. Installed new lamp ( BP96-00826A ) still no light. There is a loud humming sound.
Hi:
This is and indication of a bad color wheel assembly, you can replace the color wheel yourself, there are lots of Youtubes videos on how to do this.
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
1helpful
Samsung HLP4663WX/XAA picture went out, started making strange noise, all lights on power button came on.
Sounds likea bad color wheel to me, or possibly a lamp has blown. If the noise is a humming sound--it is the CW--if you hear a "sound like a sizzle, for a few seconds and then normal, and this repeats a few times--the lamp has blown.
Samsung hl-p4663w
It sounds like the dmd board
on the light engine
this needs a tv repair guy
Samsung dlp hl-p4663w
you need to find out what mage it blow to get the tv to work again
3helpful
4answers
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
