Plz tell the solution
MY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
mY Dear:
First:
Secend Option:
*#7370# or *#7780#
Very Best Solution:
mY Dear:
First:
Secend Option:
*#7370# or *#7780#
Very Best Solution:
SOURCE: about installing virus
use a data cable to the PC and scan your phone using the anitvirus of your PC, its much easier and safer
SOURCE: i have new nokia 5130 but its hang some time
sometimes the call divert option comes on the phone dont worry its not the phone
second try to free up some space on the phone memory and external card
switch the phone off and turn it on after 2 minutes it will work
SOURCE: how i can Format My Mobile Nokia 5130
heyyyyyyyyy
does any one know how to format my phone memory ?????? [:X] [:X]
iam facing a big problem .... my phone memory is 824KB onlyyyyyyyyyy what can i do now ???? [:X] [:(]
& that*#7370# dosent work on my handset nokia 5130 xpress music.
SOURCE: i have nokia 5130 mobile phone.and i have 1gb sd
hi....
please try this
1.Download the FE explorer from this site http://gallery.mobile9.com/f/1210278/
and install it to your mobile phone.
2.. open up FE explorer.
3.. Go to C:\system\ folder and locate a file called mmcStore. Scroll down till you find it.
4.. Copy it to C:\nokia\others
5. mark it
6. click options
7. FILE>RENAME
8. change the name to "MMCSTORE.txt"
9. try to open it, (that should be your password, if nothing happens then go to 10.)
10. connect phone to pc
11. Open the file from C:\NOKIA\OTHERS\MMCSTORE
12. copy the file to your desktop
13. open with Windows notepad/ microsoft word
14. that should be your password
thanx
