This is an HD TV yet for some reason cannot hookup the PS3. Everything has power, directv is hooked to the "composite rear 1" and shows picture & sound perfectly yet shows nothing when i swtich the ps3 cords in to replace them. The two audio and 1 video cords for the PS3 dont seem to work on any channel, in any plug. PLEASE HELP!
SOURCE: ps3 gets sound but no picture when using hdmi cord
hi theres is 2things you can do leave the scart in then go to settings and select hdmi or plug the hdmi lead in on its own switch the ps3 off leave it for 10 seconds and then switch it back on it should then ask you to select hdmi and go through some settings hope this works friend had the same problem
SOURCE: norcent not working
We have ten LT-2722 with similar power problems, at beginin the monitor turn on and off after few minutes or hours, then no turns on at all. But the problem is not at the Power Board, is a bad contact or damage in a integrated circuit U403 (GM1501-BD) at the Main Board, unfortunatelly this IC´s pins are unaccessibles so you must replace the all Main Board (Part Number CBPFF84KMGNCT)
Good Luck.
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
SOURCE: INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
SOURCE: no sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
