Question about Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Plasma TH-42PZ80U HDMI do not work after lightning storm
I have a Panasonic Plasma HDTV Model: TH-42PZ80U. Lightning hit pretty close to the house and I think jumped to the coax coming into the TV and to my cable modem. The cable modem is fried, and the HDMI ports on the TV will not work anymore. The component and every other port I have tried so far is working along with coax. When connecting an HDMI cord from my computer to the TV's HDMI port the computer recgonizes that it is a Pansonic TV, but will not show on screen with the correct resolutions set to send to the TV. I use my computer all the time on the TV because it has a blu-ray burner on it. I have tried the reset within menus. I have not tried the Volume(-) and menu on remote reset yet because I am not home to try it right now. Some people are telling me it is the A-Board and it will be $300-400 to fix. Another place told me it was likely the signal board and it would be $200-250. The power button does not give me any error blinks at all. Any thoughts on getting this working for $200-250? If it is going to be more like $400+ I am just going to give it my son let him use it by component connection and buy a new TV.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,001 Answers
  • High-speed,transmission rate synchronization and transfer music, contacts, quickly and efficiently.
  • Flexible cord,lighting cable perfect forevery house hold ,when you want to use your device in bed or other on soft place
  • Durable,with nylon braided,better to protect the cable.
Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters Lightning Cable USB Charger...
Posted on Dec 27, 2016
    New Friend:
I don't have a solution, unfortunately, but your problem is nearly identical to mine. It even seems to have happened on the same date (7/27/12)! Do you live near Dener by chance? Anyway, we have Direct Tv, and ended up with 2 fried HD DVR boxes and 2 TVs on which the HDMI connections don't work after lightning hit close to our house on 7/27. Those boxes were replaced, as was part of the Direct TV dish. The only difference is, whereas on one TV component connections (red/white/yellow cables) allowed the TV to work normally, on the other (my 50 inch Panasonic Plasma TCP50S30) even the red/white/yellow cables did not work. Now I'm scouting the net for tips on what else to try before I possibly have the Panasonic looked at, which I am hedging on doing since I got it for only $600 new in the first place. Have you found out anything else since you posted this? Good luck to you...
Posted on Aug 05, 2012
6ya staff
SOURCE:
marketex
Maurice B Thomas
  • 371 Answers
SOURCE: TH-42PX60U All output ports works but HDMI ports
Problem is with your ISP/Cable Company accepting the installation as one with HD clients, which while
not necessarily costing you more, must be specified to the cable box by your installer.
Make the call.
Posted on Apr 17, 2009
crapiemael
Crap Iemael
  • 241 Answers
SOURCE: HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
Posted on Jul 21, 2009
Azrael SRL
  • 11800 Answers
SOURCE: My Panasonic Viera 50" 1080i
The Panasonic doesn't detect the presence of the signal on the antenna input so it just skips it. shut down the player and turn the cable box on before attempting to switch sources.
But why aren't you using the Composite RCA connection on the cable box ? Not only you would get a much better image but the tv would detect that change in the AV source and should switch by itself. If it doesn't then the control processor is faulty and the entire mainboard will will have to be replaced
Posted on Nov 05, 2010
Brian Cardenas
  • 12 Answers
SOURCE: model # TH-42PX80U tv was
You are better off replacing the power supply board. Usually the mother board will output a power ok signal to turn on the TV only when the power supply is working correctly (all voltages are within specs), similar to a computer, having said so, if you have the schematics you can verify those voltages being output from the power supply upon depressing the power button. The +5v stand by voltage is most likely ok, since the mother board is at least providing you with the blinking light. It is the +12V and +24V which are not being output, along with any other auxiliary voltages. I would suggest either having a replacement board (power PCB) installed or otherwise feeding the needed voltages by substituting those missing ones with a variable DC power supply, just to verify it. Follow above only if familiar with electronics and electricity. safety first!.
http://www.HDalacarte.com guy audio/video/computer technician for over 30 years
Posted on May 26, 2011
Testimonial: "I was hoping for someone with tech knowledge, and would like to thank you for the possible solution to my problem... SR."
gopakumarg43
  • 76171 Answers
SOURCE: Panasonic TH-50PX80U won't work after
Hello
If cable box converter has damaged, there is no question about the main board of your TV. It has been damaged. Before replacing it, you have to check the power supply board also. If the TV has been pluged to power supply, surely there will be fault to it also. We can't predict the exact fault occurs during a lightning, because Trillions of volts are passes nearby. You have connected the TV with cable connection and to the home power supply too.
Just replace the main board first. If it does not hel you, replace the power board too. I hereby send picture of both boards.
gopakumarg43_14.jpgThe first one is main board and the other is power supply regulator board.gopakumarg43_15.jpg
Posted on Aug 20, 2011
House struck by lightning and no picture in tv
I am so sorry but you should have claimed that on insurance. The amount of damage to all the solid state items in that set would mean that you are going to be replacing everything.
Dec 10, 2013 | Panasonic TH-50PX75U Plasma HDTV
I have a Panasonic TH-50PE700U
I think if you Google research the model with "10 blinks" you will likely find it is bad power supply or related to it.
Apr 29, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic th-42pz80u...dead set...red LED blinks twice at turn-on...the 15v supply on pin 1 of P7 comes up for a second then shuts down
I'm no expert but I have the same tv I'm trying to fix,different problem from yours.I think you can take a resistance reading from that pin to ground and if there is a short,you can start unplugging different boards and when you have the right one the short will go away,if not its the power supply.Put in a search on google with something like board layout for TH-42PZ80U and click on the link 11th generation and you can tell if I told you right or not
Oct 12, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have tv model TH-42PZ80. The power red light flash 12 times and make a stop then it begin again. The tv does'nt power up. Do you think is the power supply or maybe just a capacitor on the board? Thank...
I would look in the manual to see what the flashes means. It should tell you there or online at the tv brands website. I would think it is a board tho. At least that's what it sounds like
Mar 29, 2011 | Panasonic TH-42PZ80U 42 in. HDTV-Ready...
Can you tell me what a Panasonic Viera Model TH-42PD25 would be worth today? I'm thinking of buying one second hand and aren't sure what I should pay. Thanks!
Hi.
Second hand price is difficult to say, probably about $500. If the unit is in good shape it does not go down too much.
New RRP is over $1000, offers however start at about US$600 (about £400 in UK). Probably you can find a little cheper in Ebay.
Here a link: Panasonic Viera TH-42PZ80U
I suggest not buying a second hand plasma. Plasma TVs have a couple of weakness points, and often break down after few years usage. If you buy a second hand you do not have any info on its usage, and you may find yourself in need of changing a sustain board within the year.
Oct 05, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panny TH-42PZ80U Plasma TV No display on Power-up
I had this same exact issue. Panasonic sent a repair tech to my house since I was still under warranty. The tech was able to fix me up in about 10 minutes. He replaced the "brain" or A-board and now I'm back in business. This is NOT a power supply issue. The brain is the circuit board that has all the inputs attached to it (component, hdmi, etc...).
hope this helps!
Aug 02, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma tv
complete guide here...http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TH-42PZ80U
Mar 03, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
No screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Viera TH-42PZ80U Plasma TV Logo
903 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
