Forgot your Windows XP password? Don't worry about that. I have troubled the same thing before. I searched from internet and solved the problem. Now i want to share with you and hope it will really help.
Solution 1: If you have owned another available admin password, it can work. Just log on your PC->Click "Start"button->Control Panel->Add or remove user account->Select the account you want to reset->Change or Remove the password. Then the password will be reset.
Solution 2: You can use one of the password recovery software tool to reset the forgotten password. Here, i would like to introduce you one of them, which i have applied. It is really a good hand. That is Windows Password Reset . The process is following.
Step 1: Download the Windows Password Reset Deluxe from http://www.windowspasswordreset.net and burn a erasable CD
Step 2: Boot the CD into the ISO image which is provided by Windows Password Reset Deluxe
Step 3:BIOS settings
Step 4:Recover the Windows XP admin password.
It is an easy-to-use way to reset windows password.
You can have a try.
You can have a try.
Good guidance! I forgot my old computer login password on Windows XP a few days ago.
Forgot Windows XP password? I get solution from Windows Password Key. Download it from http://www.lostwindowspassword.com
SOURCE: Hard drive size in a Dell Dimension 4700
nope, have one here that I put a Terabyte drive in and it is working great.
SOURCE: ''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
SOURCE: forgot my password to my dell dimension 3000, how can I reset?
It's a large file, but you can download and burn a copy of:
http://www.ubcd4win.com/
It's a bootable cd that has a password recovery tool plus a lot of other stuff.
SOURCE: connecting dell dimension 4600 to home theater.
If you have either an Optical audio out connection or a pair of rca connectors you should be able to do this
