This is an air flow issue. Take the hose off the back of the dryer and run it and see if the error goes away. If it does not, something is plugging the inside of the dryer airflow.
don't forget the exhaust tube coming from the back of the dryer and leaving the building. those can get pretty restricted with lint. Another place to look is inside the cabinet for lint. Getting these cleaned regularly can prevent a fire.
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
The AF stands for Low airflow condition. We had it too. Check the lint trap first as it is the easiest. Then check the dryer hose ductwork make sure its not crushed or blocked. You may need to clean the line from the outside too.
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not obstructed. I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw). If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
af code falhing
