Hotpoint Ultima WF865 Front Load Washer Logo
Posted on Dec 14, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code on display panel
Error F-12 has come up on washing cycle with water pouring into drum and machine fails to complete wash cycle.
Ginko
Level 3:
  • Hotpoint Master 19,396 Answers
  • Posted on Dec 14, 2008
Ginko
Hotpoint Master
Level 3:
Answers
19396
Questions
25
Helped
8073390
Points
55462
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Bosch Avantixx6 VarioPerfect problems
If your Bosch Avantixx6 VarioPerfect washing machine is beeping and the light is cycling through the spin cycles without any other noise or action, it could indicate a potential issue with the machine. Here are a few troubleshooting steps you can try:
  1. Check for error codes: Some Bosch washing machines display error codes on the control panel when a problem occurs. Look for any error codes or error messages that may be displayed. Refer to your washing machine's manual or the manufacturer's website to understand what the specific error code means and how to address it.
  2. Check the door/lid: Ensure that the door or lid of the washing machine is securely closed. If the door is not closed properly, the machine may not start or may display an error. Open the door and close it firmly, making sure it latches properly.
  3. Check water supply: Ensure that the water supply to the washing machine is turned on and there is an adequate water supply. If the machine doesn't detect sufficient water, it may not start or may display an error. Check the water inlet hoses and the water supply valves to ensure they are properly connected and not blocked or kinked.
  4. Power cycle the machine: Turn off the washing machine and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This power cycle may help reset any temporary glitches or errors in the machine.
  5. Contact customer support: If the issue persists and you are unable to identify the cause or resolve it on your own, it's recommended to contact Bosch customer support or a qualified appliance repair technician.
2answers
My frigidaire washing machine displays E11 error and stops before completing washing cycle. How can I trouble shoot? I plugged and unplug it didn't help
On many machines the E11 error occurs as one or more of these connecting wires break, this may be due to excess movement from unbalanced loads. To prevent this when washing any heavy items ensure there are enough heavy items to spread around the drum to help the machine balance its load.
Washer will not complete cycle sends F20 code
he f20 (or fh) error code on a Whirlpool Front Load Washer is an indication of a water supply issue. To remove the f20 error code from the display panel, press Pause/Cancel 2 times. If that did not clear the error code, see below for what may be wrong
heres a link...https://removeandreplace.com/2016/01/12/whirlpool-washer-error-code-f20-troubleshooting-front-load-washing-machine/
2answers
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Hi my Zanussi ZWG 1120M washing machine has stopped spinning, no error code is displayed, what could this be?
First check if the water remaining in the drum?
If it is, then the fault is in the drain phase (drain pump,filter...etc.) before the spining cycle.
Otherwise, faulty is motor, belt, electronic....etc.
By the way, model is unknown to me.
Dado
2helpful
2answers
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
4helpful
Lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
2answers
My machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
