I had the same issue. I just finished tearing mine apart only to find that the lock just wasn't engaging with a slot in the base of the mixer. Try lifting up the head of the mixer to expose the height adjust screw in the hinge between the base and the head. By tightening mine down a couple of turns, the lock can engage the slot again and the lock works. You may have to do a little tweaking to find the right balance between height adjustment and latch functionality, but at least you won't have to tear your mixer apart like I did!
I turned the height adjust screw 1 turn and the problem was solved! I would say that anybody else who is using this method should start by turning the screw a little a bit at a time until the locking mechanism works. I can imagine that you don't want to tighten it too much.
Thanks again!
the locking pin won't go all the way to the lock position, but it seems to be locked into place, though...
can't push hinge pin back into mixer
