It seems that the on the menu, it skips over the icon that is for editing channels. I moved and wanted to hook up a digital antenna to the tv and can't seem to be able to get the channel scan to kick off.
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
SOURCE: Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
Having the same problem and wondering if this solution worked :D
SOURCE: the local cable company has
Hi, You need a analog and digital tuner in the TV, which it sounds like you don't have, or a digital cable box.
