Nintendo Wii Console Logo
Amanda Noble Posted on Jul 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wii not turning on?
One day it was working, the next day it won't even turn on, by using the console itself or the controllers.
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Jul 30, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1185579
Points
16067
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
5 Related Answers
A
Anonymous
  • Posted on Jul 07, 2008
SOURCE: wii console not turning on
I GOT ANOTHER PROBLEM. mY WII REMOTE NOT CHARGING WITH THE CHARGER.
BY THE WAY UNPLUGGING FOR HALF AN HOUR WORK FOR ME TO TURN ON MY WII CONSOLE.
Anonymous
  • Posted on Nov 20, 2009
SOURCE: My wii console turns on and you can hear the main
Did you lookat the cables tv as well. Use a omh meter to check.
.If everything is ok next is your chip in side.
Anonymous
  • 7 Answers
  • Posted on Nov 30, 2009
SOURCE: I just put new batteries in my Wii controller
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through
Anonymous
  • 8197 Answers
  • Posted on Dec 11, 2009
SOURCE: unable to sync controlers
please go to link below to see my tip on how to sync.
http://www.fixya.com/support/r3557442-wii_remote_not_being_recognized_wii
Anonymous
  • 42 Answers
  • Posted on Feb 10, 2010
SOURCE: nintendo_gamecube console wont turn on
plug it in duh
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Wii won't turn on.
Wii motion plus controller won't turn on
open your wii controller battery compartment and your wii memory card compartment theere will be red buttons press them then try again this has happend to me before and it worked.
Wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Situation Not Resolved:
If the system still won't power on, the system and AC adapter will need to be repaired. To start the repair process, click here.
Wii Console Turns On, But Has No Power Light Situation:
  • The power LED on the system does not come on, but the system still powers on and plays
Information:
If the Wii Console is still working normally, it is likely that the power LED is broken.
This issue will remain limited to the Power LED, and will not get any worse.
Unless the system is having other problems, continue using the console regularly for a few weeks to determine whether this interferes with the enjoyment of game play.
If, after using the system for awhile, the Power LED not coming on is too distracting, the Wii Console does carry a one-year warranty.
We are happy to inspect and, if necessary, fix the system at no charge within the warranty period. To start the repair process, click here.
function rvl_ts_sys_power_no_light_showsurvey(){ omnitureHelp("helpful_survey:rvl_ts_sys_power_no_light",JSchannel,JSprop6,"",""); } var req; var timeout; function rvl_ts_sys_power_no_light_psurv(a,sid,pid){ if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); if(a=="yes"){ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } else{ document.getElementById("rvl_ts_sys_power_no_light_s_yes_button").innerHTML=""; document.getElementById("rvl_ts_sys_power_no_light_s_no_button").innerHTML=""; } var url="/consumer/surveys/surveySubmit.jsp?a="+a+"&sid="+sid+"&pid="+pid; req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) } function rvl_ts_sys_power_no_light_psurvr(){ if (req.readyState == 4) { if (req.status == 200) { clearTimeout(timeout); var outString=req.responseText.substr(req.responseText.indexOf("##")+2); outString=outString.substring(0,outString.indexOf("##")); document.cookie='rvl_ts_sys_power_no_light=answered; expires=Wed, 28 Dec 2011 02:16:21 GMT+00:00; path=/'; document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML=outString; } } } function rvl_ts_sys_power_no_light_techDif(){ //it broke document.getElementById("rvl_ts_sys_power_no_light_s_folowup_div").innerHTML="Thank you for your interest in helping us improve our content. It appears our survey system may be temporarily down. Please try again later. If you need further assistance, Click Here to contact us."; } function rvl_ts_sys_power_no_light_clearboxsurv(whatto,box){ if(box.value==whatto)box.value=""; } function rvl_ts_sys_power_no_light_fsurv(form){ var url="/consumer/surveys/surveySubmit.jsp?p=7" var reasonSet = false; for(var i=0;i-1)reasonSet=true; }else if(form.elements[i].name.indexOf("question2_answer")>-1){ url+="&"+form.elements[i].name+"="+escape(form.elements[i].value); }else url+="&"+form.elements[i].name+"="+form.elements[i].value; } if(!reasonSet){alert("To help us improve our content, please indicate why this page wasn't helpful");return false;} if (window.XMLHttpRequest)req = new XMLHttpRequest(); else if (window.ActiveXObject)req = new ActiveXObject("Microsoft.XMLHTTP"); req.open("GET", url, true); timeout = setTimeout("techDif()", 5000); req.onreadystatechange = rvl_ts_sys_power_no_light_psurvr; req.send(null) }
My wii won't turn on
Information:
What To Do:
1helpful
Wii controller won't work with gamecube game in wii console
Gamecube games don't have the proper coding installed on the discs in order to receive commands from the Wiimote. You'll have to have a Gamecube controller to play Gamecube games even on the Wii console.
Remotete looses connection. If I leave a game switched on and put the remote down for a while, when I return there is no curser on the screen, and no way of getting it back. The only way is to leave it...
Hello there!
What this looks like is a problem with the batteries. Your batteries might be very low and need replacing. I would suggest replacing the batteries in your remote and seeing if that works.
If this does not work, you can try permanently syncing your Wii remote again.
You can do this by:
Step 1. Turn on the Wii console.
Step 2. Open up the back of the Wii remote and press the little red button that says "SYNC." next ot it.
Step 3. While the Wii remote's 4 LEDs are flashing, press the big rectangular "SYNC." button on the Wii console (in case you didn't know this, the Wii's SYNC. button is located under the plastic flap on the front of the Wii console, with the SD card slot). Wait a second, and the remote will register as a remote on the Wii console. This is the only sure-fire way to sync a Wii remote. TIP: make sure when you turn the console on, that you press A on the remote you want to be first player first, or it might get the remotes' player orders mixed up. They will still be synced to the console, but just in undecided orders. You will have to press A for the remote(s) you want to use every time you turn on the Wii console.
If all else fails I would suggest contacting Nintendo support at 1-800-895-1672 and they should be able to help you further. You could also go to your local electronics store that sells Wii products and get a replacement and follow the syncing as stated above.
Thank you for coming to FixYa, please rate!
1helpful
When U turn the wii on & put N a disk, it errors & it wont work
try to purchase an optical cleaning disc and let it clean your drive inside your wii. also make sure your discs are clean.
3helpful
I just put new batteries in my Wii controller & it won't turn on. The Wii itself is on, but the controller won't turn on. How do I sync it back?
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
