The touch screen on my panasonic lumix tz 20 camera has suddenly stopped working.
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
SOURCE: Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
SOURCE: lumix fz-20 panasonic has message
Does the camera start up as normal? Is the message intermittent? When does the message appear? (i.e. when zooming, when taking a picture, etc)
Unfortunately this message doesn't have one clear meaning. Or rather, it does - it says "something is wrong with the camera". From what I noticed with Lumix cameras, lens is usually the reason for this. (e.g. if there is a bit of dirt stuck in lens gears you would end up with the same message). If it's dirt in the lens, the solution isn't easy, you either need to have it repaired at panasonic service, get a replacement lens from an otherwise defective donor camera from e.g. ebay and replace it, or alternatively dismantle and clean the lens yourself if you're brave.
On one occassion I saw this message appear due to a problem with flash circuit. Disabling the flash sorted it out.
I would recommend first trying to disable any fancy options in the menu (e.g. flash, image stabiliser, macro, etc) and resetting the settings to factory state via the menu.
Good luck,
Raf
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
