Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
I understand that you are receiving water at the bottom of your Frigidaire refrigerator, model# FPUI2188LF. What can cause this is either humidity coming from outside your refrigerator or maybe from the crisper drawers. Make sure your crisper drawers are set for a high humidity. Another thing that can cause moisture build-up at the bottom of your appliance is not covering your foods. Make sure that all foods and drinks are covered to cut down on moisture floating around inside your appliance. Hope this is helpful.
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
