Removed a radiator in one room only, it's valve opened during the night, had a leak,Pressure dropped in boiler, refilled but then it was over filled, bled radiators and reduced the pressure to 1, tried to start boiler again and it made clanking noise,did not fire up, error code came up as E something then went to F20.
Its Sunday and I havent got the moey to call out a plumber, any ideas??
Have no hot water.
Thanks
I assume losing pressure through the PR means Pressure Relief Valve (PRV) or temperature pressure (TPR). Open in TPR may mean boiler is overheating/overpressurized. Open in PRV means the Pressure Reducer/Fill Valve in the fill line of the boiler is broken.
House Water Pressure in a home is 30/40 PSI min to 60-80+PSI max.
Boiler PRV/TPR are set at 30 PSI open (SYSTEM PRESSURE) so too high a house water pressure will open the PRV/TPR. Replace the reduction regulator on/in the fill valve assembly
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at.
So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp.
These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots.
I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation.
We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard.
Best of luck!
The expansion tank is located on the header leaving the boiler. If it is a newer style than it will be a cylinder, most likely hanging above the boiler. It will have a valve on the bottom of the tank that looks like a tire or bicycle valve. If you put an air gauge on the valve stem it should read 12 psi, if it reads more, say closer to 30 psi, then the bladder is broke, and it should be replaced. If there is less than 8 psi, then there is probably a slow leak and the tank should be replaced.
If it is an older expansion tank, it will most likely be mounted in the ceiling of the boiler room, it will be a large steel cylinder, that is piped into the boiler, and should have a drain valve on on side of it. If this is the case, connect a hose to the valve, and allow all the water to drain from it. This should solve the problem if it is your expansion tank. Hope this helps.
If there is no leak anywhere in the system [pipes & radiators] Check the emergency pressure relief valve. It usually is at the base of the boiler and drains to outside [15mm pipe] where, if the valve leaks, water drips can be seen.. Looks similar to the picture with your query Renew the valve You can take it apart and clean it but I've never found that to be successful in the long term
on the pipework below there may be a silver braided hose with one or two valves on the end. turn the valve(s) so the handle is inline with the pipe this will allow water from the mains supply into the heating circuit , remember to keep an eye on the pressure gauge. fill the system to 1bar cold then shut down the valve(s). turn on the boiler and it should be ok, if you lose pressure again then you may have a leak somewhere which needs to be found.
