I am hooked up to DirecTV with my HDTV. I do not have HD programming yet, but am using an S-Video Jack to receive great digital signal. The signal is excellent, but for some reason the voice track for many shows is not in sync with the video. It appears as if I am receiving audio faster than the video. I am just using standard red and white audio jacks plugged directly from my Insignia 32" TV into my DirecTV receiver. The DirecTV receiver is only about 1 year old.
Oddly enough this isn't off all the time. It mostly happens when watching events shown live such as newscasts, sporting events, etc. Most sitcom type shows seem to appear to be in sync with audio and video.
Happens mostly on your local channels right? This is a issue with the local broadcaster and not directv. Due to the digital transition this has been a widespread issue. Until the local affiliate for NBC, ABC, etc. fully transmit a digital signal then this sync problem is to be expected.
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
You're correct and that is exactly how I always recommend setup (contrary to what the manuals tell you). It makes no sense to me to run any signal through any electronics or interconnections that neither use it nor improve it. Hence, I have NO SOURCE VIDEO going to or through my receiver and NO high end audio going to my TV (which could just as well be a monitor with NO audio capabilities, right)?
Audio electronics should receive the BEST digital audio directly from it's root source.
The TV should receive the BEST video directly from ITS root source.
THAT is why most all high end A/V gear has separate audio and video in/outputs.
If that means you have to make some switching choices when using different sources, oh well. At least you won't have experience potential degradation from multiple hops or have to troubleshoot problems that could be anywhere in that chain.
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television * HD satellite or cable receiver * DVD player * Stereo receiver * AV cables * Cable connector * HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Hi, it's a general process to connect any receiver to a HD TV.
How to Hook Up a Receiver to an HDTV
Things You'll Need:
Instructions
Tips & Warnings
on your directv box, go to menu, setup, setup again, then audio, then dolby digital on the right and turn it on. assuming you have an optical audio cable from your sat box to your onkyo.
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
TV is HD correct? Use the Y/CB/CR from the Sat to the TV. Use the Digital optical cable for sound from the sat to the receiver. Use the s-video from the dvd player to the tv and the l/r to the receiver for sound. I would suggest upgrading to another set of Y/CB/CR cables to connect your dvd to the TV and benefit from better picture. Also, buy another optical cable for dvd sound (so you can enjoy surround sound). Your receiver has two optical inputs so youre covered there.
