I dropped my camera while it was on and now the lens in stuck out and it wont turn on...i did turn it on a couple of times but when i tried ti zoom in it shut off again and will not turn on and the lenswill not go back in
SOURCE: Lens stuck camera turing on and off
Lens mechanism is shot. A repairs is not likely to be an economic proposition Contact Kodak customer support for a try
SOURCE: Shuts off when i try to zoom.....
I was also having a similiar problem with my z1275 and tried the "vacuum" thing. BINGO! It worked, and I was about to send the camera back to Kodak for servicing. You saved me money.
What did I do?
I turned my vacuum on, stuck my lense into the vacuum tube, zoomed all they way IN and then turned the vacuum off. My camera now works perfectly.
Before using the vacuum, I was only able to zoom about 50% before the camera would turn off. Thanks for your help.
SOURCE: Zoom out and it shuts down
Don't think you'll have to send it in for repair. How old is your battery? Keep in mind that it isn't meant to last for more than a year or two, regardless of how often it is used. A camera will automatically shut down if its battery power is getting low. This usually occurs when the camera is doing power intensive actions, such as zooming (it uses a motor). Anyways, Amazon has some generic options for you if your battery may be over-the-hill:
http://www.amazon.com/s/ref=nb_ss_p?url=search-alias%3Dphoto&field-keywords=kodak+m1033+battery
SOURCE: Lens only goes thru zoom cycle then shuts off
Your fix could be as simple as cleaning the camera's battery contacts,
or it could be something more serious and expensive. Before you pay
for expensive repairs that you may or may not need, check the Kodak
Help Center by clicking on the link below. It uses a simple Q&A
format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
SOURCE: My camera shuts off when I my zoom is nearly halfway through
Make sure your batter is fully charged, and is not bad. This kind of reaction can happen with a weak battery or partly charged.
If that is not it, then the camera needs repair.
