Sony RM-VZ320 Remote Control Logo
Posted on Jul 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my name is Oscar I have a tv element model FLX-3211B and do not work the remote control codes sony RM-VZ320 and need help please!
TV element model FLX-3211B
ernesto cuadra
Level 3:
Top Expert:
  • Sony Master 12,223 Answers
  • Posted on Jul 30, 2012
ernesto cuadra
Sony Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076339
Points
34431
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d
go to the next web pages, give your model, mark.
www.remotecodelist.com + remotes.com
God bless you
5 Related Answers
A
Anonymous
  • Posted on May 13, 2008
SOURCE: older sony tv kx-m270 1986 model, missing remote control
This is only a TV monitor. It needs to be connected to a reciever, the reciever has an infrared remote. The AVU-270 is what was originally included if you bought this as a set along with the APM-X270 Speakers
Anonymous
  • 752 Answers
  • Posted on Sep 14, 2007
SOURCE: trying to find code for my gateway T.V
If you have the original remote, you have the Sony "learn" the signal from it. It's not too difficult and the manual will walk you through it.
Anonymous
  • 14 Answers
  • Posted on May 12, 2008
SOURCE: sony remote RM-V202A
Follow these steps to program the remote control.code for NEC:(003, 012)
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the S button.
  3. While holding the S button, press and release the POWER button
  4. Release the S button.
  5. Press and release the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code.
  7. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  8. Press the ENT button.
  9. Point the remote control at the component.
  10. Press the POWER button to verify operation.
Anonymous
  • 19 Answers
  • Posted on Aug 29, 2009
SOURCE: Code for Sony RM-V310A remote.
try going to and plug in the information there and see what you get
http://www.oneforall.co.uk/us_US/support
Anonymous
  • 208 Answers
  • Posted on Mar 19, 2010
SOURCE: Unlock code from remote RM-X96.
http://www.fixya.com/support/t351405-sony_rm_x96
2answers
What is the code for a sony vz320 remote control
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device name list in alphabetical order. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SONY RM-ADP089 CODES FOR RCA TV
There is no setup code to RCA TV, with this remote control. If you wish to get more codes and other details. It has setup code list, and setup procedure to may popular brand remote controls.
http://electro-medical.blogspot.com/
Maganvox product codes
There is no setup codes for Magnavox with this Sony RM-VZ320. . For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts. . If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device.
Code philips magnavox tv learning
0938,0928,0975,0919. Check these codes. If you wish to get more, check these links.http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
1helpful
Programming instructions for a sony rm-vz320 to program a JVC TV
Programming instructions are too much to type in here. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Check this site too.
Codes to make Sony universal remote rm-vz320 control my RCA 46LA45RQ
For mine the rca listed code 00178 almost worked (no movement during input or menu)
Code search found 01265 which works all the buttons I use.
I had sound but no picture on my Element Electronic FLX 3211B LCD Television Set. I replaced two capacitors, and now I have lit screen by turning on the tv on the side panel. Remote does not control the tv...
You might have bad capacitors still that you cannot see. The only way to be sure is with an ESR meter. Check all the connections on the boards again to be sure that the sensor for the remote did not come off.
What is the code to run a sylvania tv with a sony bd RMT-B107A controller
Hello
Setup codes for Sylvania Tv with Sony RM VZ320 remote control are:
00054/00171/01271/ 01314/01394/01864/01886
OK.
Hi i'm trying to programme my sharp stereo with a sony rm vz220 remote control. But can't get the correct code. The only code that i got was 60048. But it does not work.. Help plz..
According to the Sony Support site for this remote, receivers are NOT supported at all. Additionally, only a handful of codes are available for Sharp electronics. They are for the following devices:
Blu Ray, CD, DVD, DVD Recorder, TV and VCR.
All the codes used for the devices above are:
12250, 70034, 70037, 70180, 10630, 10675, 12250, 10675, 00818, 60048 and 60848.
You could try these codes one at a time and possibly gain some remote control capability - but that would only happen by chance. The codes above are the ONLY ones built into the RM-VZ320 remote for Sharp brand products, and if none work for your equipment, Sony says you should use your original equipment remote to control it. Not very helpful.
You can either do as they recommend, buy a pre-programmed remote that supports your device, or buy a pre-programmed remote that supports "learning". Learning remotes are universal in that the products not built in to the remote can be learned by holding the original so it points at the learning remote and pressing function buttons so that the learning remote "records" the buttons pressed on the original. It can take some time to do this, but you are assured that the remote will work with you device. Of course, you must have the original remote to do this though.
I hope this helps and good luck! Please rate my reply. Thank you.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
