My daughter cannot remember her password for this phone samsung gravity sgh-t459 tmobile
Your problem is not a simlock but a user code (also known as security code, phone lock, pattern lock etc).
You can reset it for free here:
http://www.unlocksamsungonline.eu/free-phone-lock-unlocking/
Phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
I cant remember my pw for my phone this is my IMEI number 353060 03 105004/7 03
Hello, my phone IMEI is 35306103053469/203
356347/02012796/0
This is my imei my phone locked with network but my phone locked with phone cod I can't unlock please helps me my mail is [email protected]
Hello this is my imei 357052726717 and357058052726715 my gt e-1207y is locked pls help me unlock it. [email protected]
SOURCE: how do i unlock my samsung gravity sgh-t459 for
1. Turn on your Samsung Gravity without
the SIM card inside.
2. Now type in #7465625*638*UNLOCK_CODE#
Where UNLOCK_CODE represents your 8 digit unlock
code. (Warning:
Entering more then 3 incorrect unlock codes, may permanently lock your phone!)
3. If everything worked, your phone will say
“Network Lock Deactivated
You can get unlock code from your service provider. Hope this helps
SOURCE: need to unlock phone
Sometimes you can get in by the default code 0000. If that doesn't work you will have to contact your carrier. I have ATT and my father has had the same problem several times, we called ATT and they were able to crack his code from their end and tell him the code.
Good Luck,
John
SOURCE: HOW DO I GET MY UNLOCK CODE FOR SAMSUNG SGH-T459
Ok,enter wrong password for more then 5 times,it ll ask u to enter the puk number....now call your customer care and get the
puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
SOURCE: how to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
