HELP!
The power supply regulator board should be checked. Check this link, and select the site named 'Electro-help'. All details are described there in detail.
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
SOURCE: SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further
SOURCE: My 50 inch plasma LG tv has no picture only sound. There was
My 50inch plasma LG tv has no picture only sound.
